Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 89
Thread: Let's Talk Timing Maps
  1. #41
    I don't bite
    Southern IN
    Here's the type of base ignition map smoothing that can be achieved with a 3-D tuning strategy.
    J, at a quick glance, mine is almost identical to this one. I want to play with the timing up top more to see if higher is worth it. 19* at idle with a sharp ramp to 38* at 2500 in vac.
    My actual idle timing varies because I give AEM a ton of timing flexibility at idle to stabilize the idle. (Works like a charm)
    I haven't posted mine because I don't think it's optimized yet so refrain from public posting so I don't lead anyone astray.
  2. #42
    One fix at a time verified
    Kansas
    I was never able to enlarge the graphs in ecuflash but I have been using the graphical feature. I definitely prefer that for tuning since it's so much easier and quicker to smooth the map out. You can stare at the table but honestly it's much harder to take care of any discrepancies just looking at numbers. It's easier to miss something and the average person won't be able to tell how smooth or jagged their changes are. You'd be surprised the difference there is between what you think looks good on a table format and still looks bad in graphical view.
    It definitely takes longer in ecuflash referencing the axis each time to make a change or even picking a cell, incrementing/decrementing until you see a visual change, reverting the changes, and then moving to another area of the map if you're not where you want. The 3D trace feature in AEM is nice and part of the reason I asked if ecuflash had some sort of a trace feature. It wouldn't be too hard to rescale the axis in AEM, copy your table over, smooth it out, and copy it back to ecuflash.
    Different strokes for different folks but I'm definitely more of a visual learner. I know many prefer that methodology also. Sometimes it's easy to get lost and forget the big picture.
  3. #43
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    I totally agree with you TSB. It's easier for my eye to look at a 3-d map and visualize proportionate grid squares and try to make all sides equal and smooth than it is to look at a rainbow or just Excel format numbers.
    I think graphing everything in 3-D is also a good basis for comparison.
    What do you guys think about posting fuel maps too? That's where things get interesting.
  4. #44
    Wrench Monkey Not Verified
    Rochester, NY
    As in live map tracing? If so, Evoscan has that. Not in 3D that I know of though.
  5. #45
    Kansas
    Quote Originally Posted by TwIzTeD_3kGt View Post
    That would be helpful. I'm looking for more of a 3D map tracing inside ecuflash. There isn't such a thing but it would be more useful for smoothing things out from a graphical view.
  6. #46
    One of the best tuners I've ever met was a guy from New York that flash tuned EVOs. He used the same programs as Chrome and had no live tuning. Just read the evoscan logs, hunted the cells on the tables and adjusted them. His "technique" was very highly criticized by many because he would select a large block of the map and make all the values the same number. Usually a group of 6-8 cells in a few rows. He did this to make sure you got the same numbers when putting down the hammer thus getting consistent power. This was especially important when tuning solely on pump gas with a boost controller not under the will of the ECU and you're right close to the edge where even a small amount of knock could spell disaster.
    Anyway, this guy got SLAMMED hard when some Internet tuning expert got ahold of one of his tuned ROMs and posted it on EVOm. It was the intelligence level of the 3SGTO Facebook page where somehow every know-it-all came out of the wood work to criticize the "unsmoothness" of this guys tunes. His reputation was completely destroyed in this one thread. These Internet mechanics convinced themselves that any failed engine with this guys tune on it was the result of that unsmoothness.
    Maybe tomorrow if I'm bored at work ill find the thread.
    Moral of the story: these features you guys think you need are neat, but not necessary.
    Also, don't forget that A stock car ran pretty damn good for over 20 years now with this "sloppy" and "unsmooth" timing map. I bet more R&D that went into that "sucky" stock map than I have put into the entire chrome ECU platform.
  7. #47
    I don't bite
    Southern IN
    There's a similar school of thought with one 4g63 tuner that you tune your timing at highest boost to find mbt throughout the rev range and set that for all the lower load rows as well. Ex. 15* at 35psi at 7k. He would then make it 15* at 7k for everything 10psi to 35psi.
    This way you know you are never past mbt at varying load, throttle and boost situations.
  8. #48
    Forum User supporter
    May 2013
    Fruita, Colorado
    You talking about Al of Dynoflash?
  9. #49
    Hudson, WI
    If you are only drag racing then sure - otherwise you are leaving a lot of power and efficiency on the table at the lower loads.
    -Matt
    '15 Corvette Stingray Z51
  10. #50
    Quote Originally Posted by llabmik2 View Post
    Yes.
    ...but in my search for that thread I stumbled on some other stuff I didn't realize had come up about him over the years (last time I looked into him was 09). Looks like over the years he just got lazy and sloppy. He was always a bit rude and arrogant but looks like he never backed his work when things went catastrophically wrong.
    Probably not the best example to make my point then...
