60' = 1.654
330 = 4.762
1/8 = 7.349 @ 96.46
1000' = 9.544
1/4 = 11.409 @ 120.07 MPH
Next run I got another 1.6 60' but biffed the 1-2 shift and aborted the pass.
So is anybody sure of the 13T record? I made all these passes on 93 octane pump gas as well, nothing else.
Setup:
WRX 13T's, custom 2.25" SS intake pipes. 20-21 PSI dropping to ~19.5 @7K
Ebay down pipe, gutted rear precat, stock cat back cut off next to the rear diff.
Custom FMIC with 24x12x4 Garret core and 2" hot piping, 2.5" cold. Tial 50mm BOV.
880cc injectors, AEM EMS, One Walbro 255, not hot wired. Stock rail loop and FPR.
Stock long block, ~130K on it, heads re-done 10K ago, NO PORT WORK
NA VICS manifold, switches at 3K, the short runners are slightly short than TT runners.
Southbend Rally (stage 1) clutch, stock FW
5 speed AWD trans with a Kormex front diff, NBT OS and a EK2 T-case brace.
245/45/17 Dunlop Direzza Z1 Star Specs @ 28/26 PSI.
Race weight: 3380lbs (with me), they had a scale.
It's not a street car, but it did make the 270 mile round trip to BIR on it's own power.
