Results 11 to 20 of 24
Thread: Cold Air Intake Idea!
    I got damn lucky not once, but TWICE when I had a CAI. I sucked water up and it luckily stalled the car when it hit the MAS rather than getting further up the intake. I didn't even drive through a puddle. I was just driving in some rain showers. Both times when the car stalled I pulled the MAS off and dumped about a cup of water out of the MAS and had to wait for it to dry before I could go anywhere.
    There was absolutely no gain in power from a CAI to a regular open element filter. I ran the CAI at the track and after I removed it I just had a filter and ran identical times. They are not worth the risk.
    And you asked about the check valves. I have heard on more than one occasion of them detoriating and the engine sucking pieces of them up.
    To top it all off, it would never fit the way you have it sitting right now. The CAI's found on ebay are designed for NON ABS cars because the intake is routed through the hole that the ABS unit sits in.
    Ay steathee whats needed to remove abs i dont want it im trying to clean my engine bay as much as i can
    Damn your lucky. I change my mind lol thanks
    Green wow all that from water?
    Cazenovia, NY
    Quote Originally Posted by Assy View Post
    You can do the ABS delete by using a non ABS prop valve and lines. You could even just bend and flare them yourself if you want.
    Quote Originally Posted by x2xtreme360 View Post
    How would i do this?
    Not A DSM verified
    June 2006
    Utah
    With some brake lines, fittings, a tube bender, and a flare tool.
    Yes, like Stealtee said I have had mine screw up just from running in the rain back when my car was NA and then the death of my piston rod happened when my wife ran it through a water puddle. The power gains just aren't worth the risk. Not even close.
    My friend hydro-locked his engine recently due to the fact that his intake was too close to the ground. He supposedly went through a long deepish puddle on the freeway
  8. #18
    The factory is not a CAI, its a FAI fresh air intake.
  9. #19
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    I like when stealthee and steve68 disagree Its amusing.
  10. #20
    Not A DSM verified
    June 2006
    Utah
    Well, it seems you guys haven't heard of the SUPER CAI!
  11. The Following User Says Thank You to Polygon For This Useful Post:
