Looked at it in passing.... again....
Nothing so far today.
Tried to get some of the timing covers and shit back on, but the mosquitos have just been absolutely unreal with all this rain the last couple of weeks. I could swat at my arm and kill 3 or 4 of the little bastards at once. Going to pick up some Off spray and hope that helps, may try working at night, not sure if it'll help. And I'll need new lights for the shop to do it. I tried citronella, didn't do shit. Any other suggestions for cheap relief? I'm out there for about 4-5 minutes at a time and I get covered with bite marks.
God I hate those bastards! Make sure you don't have any standing water around your house, old tires, clogged gutters, anything that can trap water. They can breed in a tablespoon of water. If there is standing water you can't do anything about then buy mosquito dunks and drop them in the water.
Well unfortunately it was from a tarp that spread over the car while I was gone. The areas that were on the ground accumulated water so they were able to breed uncontrolled for a month while I was in NY. I've been draining any and all standing water I can find, but it's too late to stop the ones already alive. Just going to have to spray the shit out of myself and hope for the best. Don't mind being bitten a bit, just don't feel like getting malaria and mosquito aids from them having a all you can eat buffet & gangbang on my calves.
Man, I feel for you guys. We have NO bugs in Cali. No humidity either.
I looked at both of them longingly, wished I hadn't worked that extra hour, instead of coming home on time to turn a wrench on them. Then, I got changed, and went to cheer practice.
Well I'm an idiot. My climate control control crapped out a few months ago. I ended up ordering another and it wouldn't work. At the time I didn't know the a/c controller under the climate control was even a thing. So I posted and tried to find a solution and no one had one until a few weeks ago someone mentioned the a/c controller. Well I ordered a new one and went to install it tis morning only to discover that I had apparently unplugged mine while removing the digital climate control. Plugged it in and everything works fine. I feel stupid lol.
After solving my mosquito problem (read: copious amounts of chemicals that said I couldn't be in the area for several hours after spraying) I started working on getting hte front timing cover and motor mount support bracket back on..I then proceeded to drop the last nut for the motor mount to support bracket between the mount and timing cover. So pulled it all back off and sure enough, wedged down by the crank cog.
All I can do at this point is just laugh and say fuck it.
Pulled it out, and took a break for lunch. I'll get back to it after. Although I do have to wonder if I'm missing a component or something there (not that there was anything there before I took it off though), as that does seem like an oversight to have an area large enough for nuts or bolts (or rocks) to potentially (admittedly slim chance) to get behind there.
