Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Failing Timing belt tensioners vs upgraded valve springs.
    Someone care to explain how stiffer springs place more tension on the slack area of the belt? I run a stock tensioner on my 4g63 running duel springs with 265lbs over the nose of my cams, revving to 9,000 rpms, with no tensioner issues. What can happen is belt flutter at high rpms. This isn't related to stiff valvesprings though.
    I don't bite
    Southern IN
    Just pulled my timing belt today to change cam seals. Tensioner still perfect. Could slide the grenade pin in after a couple of rotations. This is with dual springs, race cams and a few blasts past 7500 rpms.
    You guys with issues using new OEM tensioners?
    Jan 2012
    Arizona
    Mine was OEM. On the fence if I want to use a Solid or another OEM. Mine does move, just never returns to the 'grenade pin' position. BTW want those cam gears, I loved the way the Unorthodox ones look.
    Addicted to Crank Not Verified
    Crown Point, IN
    As everyone should know, when doing to 60k or 120k timing belt replacement your tensioner is properly adjusted if you can freely insert and remove the grenade pin after several belt rotations.
    Quote Originally Posted by Streamln1 View Post
    How far is it from the hole? 10k might be enough to stretch the belt so you can't put it back in.
    Jan 2011
    az
    Glad I read this, if I go with stiffer springs and cams I'll go with a solid tentioner.
    Good idea . You will sleep better at nite ..
    Ross 9:1 piston, H beam rods with arp bolts, *Forged crank,*Ported head with brian crower 1mm over intake and exhaust valves,*Brian crower valve springs,Oem headgaskets,*Arp headstuds*,T3 hybrid turbos with .63ar,*Tial leaded fuel wastegates with 1bar springs,*Cx racing fmic*,Arc2 in blowthru,*950cc delphis on e85,Jackhammer fuel hanger holding 2 walbros 255 hotwired ,Fuel lab fpr,*Aeromotive fuel filter*Entire fuel system done in ptfe braided black lines,*Beefed up oil cooler,*Gates racing belt*,Ninja performance soild tension setup*,3sx single pass radiator*,Tial q blowoff*,Scanmaster*,Aem twin fire*,3sx fuel rails* battery relocated to trunk, blitz dsbc, aem wideband, autometer oil pressure gauge,And so on....
  7. #17
    Jan 2011
    az
    Quote Originally Posted by donniekak View Post
    the springs put more twist load with the car off than the tensioner is designed to handle. cars with springs need to be set up tighter of it can jump depending on where the engine stops when shut off . That's ray pampena's exact words from my old thread.
  8. #18
    Jan 2011
    az
    This is what ray said to do if you use the stock tensioner with upgraded springs .
    you had cams and lifters.. so does that mean it has aftermarket springs? if so, you need to set the hydraulic tensioner down near the bottom so when the car sits there is no room for the plunger to go down far enough to make the belt jump.
  9. #19
    Medford OR
    Or shim the tensioner to reduce the clearance...
  10. #20
    Jan 2012
    Arizona
    If the belt stretched it would be pushed out farther, not pushed all the way in like mine was. it was definitely 1-2mm from the grenade pin position.
    I may try the shimming idea so it can't bottom out, a lot of these thread responses make sense, so there is more 'at rest' force on the tensioner than a stock setup, so its leaving more slack than necessary between the heads.
    Another weird thing I noticed, theres a lot of blue belt residue on my water pump from the gates belt, its on there thick enough its made the pump pulley feel rough, its as if the pump was 'dragging' on the belt or at times the tension wasn't enough to drive it, which is very bad, I also suspect this may be a tension thing, the pump spins freely enough and it also has just a few thousand miles on it.
    The timing is spot on, and I always checked it periodicly because I am paranoid (having $7k plus in an engine will do that to ya).
