Page 516 of 892 FirstFirst ... 16416466506514515516517518526566616 ... LastLast
Results 5,151 to 5,160 of 8916
  1. #5151
    Twin Turbo verified
    Melbourne, Australia
    Why do the mounts suck? Just crappy to install?
    Stock mounts have the centre hole centered while the 3sx poly mounts have the trans and upper mount off centre. Infact the tran mount the hole is higher while the other side is lower causing the engine to tilt. It Also makes them a Fucking cunt of a job to line up etc. Almost every review of them has said the same thing. 3SX are yet to actually confirm it has been done for a reason or just shoddy workmanship.
    On a positive note I noticed the vacuum line on my cruise control was cracked so replaced the line which should now fix my cruise.
    Sent from my GT-I9300 using Tapatalk 2
    Waiting install
    Build Thread
  2. #5152
    Feb 2011
    Scottsbluff, NE
    Interesting... I never had a problem with my 3SX polyurethane mounts. Although I did pay to have the rear installed (I wasn't even going to attempt it).
    1995 Dodge Stealth R/T Turbo
  3. #5153
    What did you do today to your 3/S?
    Yup poly mounts are off center. Been involved in installing 3 sets, all the same.
    Sent from the Man Cave!
  4. #5154
    yeah the first time to install them is hard, but the next time is easy because they align after a while.
    You can move the pin around with a vice or hammer to make it line up better. They just don't pay attention during assembly, they need a better jig.
  5. #5155
    Oct 2011
    Sundsvall, Sweden
    I had to fight a quite a bit with the drivers side mount when I installed my 3SX poly mounts.
  6. #5156
    Advanced Tech? verified
    anybody else see erron's new video on youtube?
  7. #5157
    JNS Engineering verified
    San Jose, CA
    I think it is not true that stock mounts are centered. I pulled my stock mounts out and measured the center pin locations and noted that the trans mount and upper mount are indeed off center on the stock mounts. I ordered poly inserts from 3SX and had them installed and clocked to the same positions as the stock mounts had. What I found was the actual distances from center were slightly off from the stockers but not too much. Now if 3SX didn't clock their assembled mounts properly then that is on them. My picture shows how they should be clocked. The trans mount hole should be offset higher and the upper mount hole should be offset lower.
  8. The Following 3 Users Say Thank You to Jimvr4 For This Useful Post:
  9. #5158
    Member
    Arvada, CO
    Swapped in a new IAC after the 20 year old part finally died. then took this picture after the rain.
  10. #5159
    Wrench Monkey Not Verified
    Rochester, NY
    The least fun I've had with the car all year.
  11. #5160
    San Jose, CA
    Wait, WTF happened to your front turbo?
