Originally Posted by
Jstarr427
Ironically I did that today. After work I threw my car up on the lift, pulled the rear flange off to check the surface on the diff, and check the rear joint. I knew they were a little stiff before, but after driving the car for the 2 days I have, the joint in the steel flange is smooth as can be, while the one in the aluminum is still stiff, but not as stiff as it was before I put the shaft on the car. I'm thinking that they must buy the yokes and weld them to the tubes, and if weld shrinkage is not accounted for, the part could shrink, and that would make the holes for the joint not concentric anymore...
None of this really matters as I'm getting a new shaft on Monday, but I also put the car in 5th, at idle it's around 40mph. underneath the car, you can see the aluminum section shaking a bit. running a pen in until it BARELY touches the shaft, you can see where it marks maybe a third of the shaft. It's worse farther forward towards the carrier bearing. so the tube is not centered on the yoke. Damn, no wonder this thing shakes at 70. I can just imagine what it looks like.
