Results 1 to 10 of 29
Thread: Inline 6 Vs V6 Discussion
    I've always felt that the V6 engine was a better design than the inline due to less weight, quite a few of the local guys seem fairly jealous of the 3000gt having a V based engine vs the heavy RB26DETT's in their skylines, yet in chat people are saying otherwise...
    DISCUSS!
    For comparisons sake, the 6g7x weights
    block 43-50kg
    crank 20kg
    heads 16kg
    girdle 6kg
    assume we add another 50kg of accessories/brackets/hardware we're talking about 150kg ish?
    1996 GTO, Owner since 2003.
    Sep 2011
    our engine is not really light though. not sure what inline 6s weight. inline is too long and too tall so not good for road racing.
    Aug 2012
    Langham, SK
    The best part of inline is the strength of the bottom end, having a larger crank and more importantly, more journals. Yes, a V-6 maybe is more compact and lighter, but an inline will always be stronger.
    the benefit to an inline is that it will theoretically make more power than a v6 of the same displacement. that, and it is naturally balanced internally. you could argue that it also benefits from having only one set of heads.
    on the other hand, the benefit to a v6 is that it can be mounted transverse or longitudinally. this also means that weight distribution can be better, because the bulk of the weight can be placed between the wheelbase, rather than in front of it (which tends to be the case with cars that have 5+ cylinders in line (viper, supra, etc). 60-degree v6's are also very good at reducing vibration--and while not perfect, they certainly provide an acceptable compromise.
    v's are inherently better suited for twin-turbo applications, and i's better suited for singles. running a dual-exhaust off an i is rather silly (i'd argue even more silly than a true dual-exhaust off a transverse engine).
    inline 6's work best when mounted at an angle, which helps lower the center of gravity. in any event though, car manufacturers have all but stopped making inline 6's. even the skyline is now a v-type engine. if inline 6's were substantially better, i don't think that would be the case. i'm guessing this partly has to do with the overlap of technology/engineering between v8's and v6's--just look at GM's vortec v6's.
    I think for this argument to be properly inclusive you have to consider the boxer, which design I believe is inherently best relative to vibration, and while well-suited to rear-mounting, it isn't limited to that.
    I was brought up to believe a longer crankshaft will always yield greater instantaneous torque due to the fact it's rotating mass works in greater unity relative to other designs, but forced induction and the various engineering tweaks to timing and valve-action more than offset the few advantages an inline offers.
    They also don't like to spin stratospheric RPMs cuz of crank-whip.
    Delaware
    Inline sounds better, is stronger, is cheaper to mod generally. V6 is shorter but in most cars is only used in favor of inline due to packaging since V layout imports are usually fwd derived cars. any DOHC engine is tall as shit, doesnt matter the layout.
    Jason
    inline 8's would be awesome if that were the case. who makes an inline 8?
    radial engines provide more torque than inlines, i'd wager.
    Inline 8s were pretty cool; my Pops had several in Buicks he owned.
    Tons of torque, but the same problems emerged; size/usage limits, they didn't pull revs, and the advantage of 'instantaneous torque' only translated to a really good 10-foot time.
    As to radials:
    http://www.autoblog.com/2013/01/10/p...ville-w-video/
    Don't believe I've ever seen a radial/6.
    Sep 2011
    inline 8 is a terrible design. 90 degree is the best for v8 because of no vibration.
    A v6 only has 4 mains, not a very strong design. Inline 4, and v8 hav 5, and inline 6 has 7.
