Cleaned my break calipers so I can rebuild them tomorrow and paint them red![]()
"Why pay for a sports car, keep is clean and shiny, mod it, and drive it like a bitch?"
My old MTX box had terminals on the back that i used. It comes with a plastic insert that the posts mount to and a gasket to seal it to the box. This is what they look like.
My box had 2 of these (one for each speaker) and they are 4 ohm not 2 ohm. I just used a circle cut bit and cut the exact size for the part of the insert that enters the box, drilled the 4 holes for the screws and bam was done, plus it adds a nice factory look to the box.
[3SX Test-Pipe to Flow-master Delta 40 Series Custom Exhaust// 99' Lifters // Cold-Air Intake // MB Wheels 5X]
Bolts work great as terminals:
inside:
outside:
what it is:
Center channel for my up coming Dolby DTS 5.1 mobile theater.
Drove it around STL.
Still gonna need an engine, lol. It also has the worst clutch ever.
I worked some more on the upper intake plenum...My thumbs & index fingers are RAW!!!
(BTW: these were older photos from the afternoon)
I can't wait to be done with the sanding part of it!! Only about another 10 hours or so & it should be ready for some buffing.-
Oh, & I also got my HPS silicone radiator hose kit & other heater hoses in today (well, technically yesterday).
Sent from the garage
Installed ebay downpipe.. car sounds awesome. Definitely added some balls remove 2/3 of the cats. Right around 3500rpms at wot the turbos initiate lift off and the car just takes off like a bat out of hell
trying to figure a way to fixate the lcdbc knob in the cig lighter trim..
New Battery
Bath
Clean inside of windows
Removal of most of the "tree sap"
Start buffing & polishing paint - half of the hood looks ok
May have to find a shop to finish the buffing...
Before
After
