Any tips on resetting the SRS system? I cant get that light off and it wont pass inspection as long as its lit up.
Sent from my DROID4 using Tapatalk 2
Very common problem. Here's 3 potential solutions:
- Track down and troubleshoot what the problem is
- Visit a dealer to have the SRS computer reset (can be expensive)
- Find someone with a DRBII or MUTTII (or purchase one for yourself), which can be used to reset the light
Some also say that they've successfully been able to reset the SRS light by turning their key to the ACC position and off 10 or so times in succession.
If none of the above is a possibility for you, many would recommend that you just pull the bulb. That's generally the easiest way to get through inspections, but it won't solve your problem.
Doesnt the light come on for a reason? If i remember right my light is on too, but for a front passenger impact sensor. Are those sensors costly?
Was yours involved in a crash or did it just go bad?
Hey Stealthify, I appreciate all that advice. I will give that a shot first thing in the morning. I wont be pulling the bulb because Virginia looks for it to turn on and then off at startup. Someone else recommended i just rewire it to the check engine light but I figure I might as well fix it proper if I'm going to go through all that mess.
Sadly, there's a lot of things that can trigger it.
Just a few of them include:
- Letting battery drain too low
- Bad Sensor
- Blown fuse
- Unplugging the car’s battery
- Removing the gauge cluster/installing aftermarket gauges
- G-Force sensors that are under each of the front fenders ($250.00 each)
- Bad clockspring (located inside your steering wheel)
- Bad ECU
- Bad reverse light switch on transmission
- Car was in an accident
- Airbag defective/unplugged
SRS: Troubleshoot SRS Dash Light - 3000GT/Stealth Wiki
I no longer have a horn and my SRS light is on ever since I had my Momo Tuner steering wheel installed. That light can be bothersome and I need to figure out how to get rid of mine.
If you replaced the steering wheel, I imagine you no longer have a driver-side airbag. This would likely trip the SRS light.
In your case, since you know why the light is illuminated, it'd probably be easiest just to access your gauge cluster and remove the SRS bulb itself.
