Results 1 to 10 of 22
Thread: Oil Pan Internal Coating
    I purchased a used oil pan a while ago and I got around to cleaning it out last night and found the black internal coating is missing in a lot of areas, it may be a result of the cleaner I used: castrol superclean. I tried scraping the edges of the coating with my fingernail and I couldn't get it to flake off anymore, but it may be a different story with hot oil in it. Would you use this oil pan like this? If not, strip it? New oil pan?
    Learn how to Powder Coat at www.powdercoatguide.com.
    I just powdercoated an oil pan but decided not to use it for fear of the heat degrading the coating over time. I feel safer using a hot ceramic coat (like what's used to coat exhaust manifolds) in something as critical as this.
    My fear is probably ill-placed.
    iowa
    Warning first : I would not do this in a race engine of.my own .
    But for years Harley , cat and many other equipment manufacturers have been.painting the inside of crank cases , oil pans and gear boxes for years to help with oil clinging to them .
    Sent from my HTC Hero S using Tapatalk 2
    I agree, I was prepping this pan to powder coat it but I will not be coating the inside so I want to make sure whatever this coating is is stable even though its missing in spots. I had it in the oven at 450 for an hour last night and I was unable to chip the coating off after. Still, I dont trust it till I get some more advice.
    I just put some masking tape over the spots and pressed it down good. I then peeled it up fast and there are black specs on the tape. So, strip it or new oil pan? If the pan was bare metal inside, I am sure all of the oil would keep it from ever rusting, but what about the oil clinging issue. Would a pan with a slick coating perform better than a bare metal pan?
    Looks to me like the coating (I believe it's teflon, actually) you find inside the cup of any decent paint-gun.
    I thought that as well. Like a frying pan coating.
    if you are confident you can get the grit out I would sandblast it and just paint it with some engine paint.
    One fix at a time verified
    Kansas
    I had some flaking on mine. I ended up scrapping off all the loose specs hoping the rest of it would stay intact while the engine was running. I didn't want to paint it or powdercoat it. I don't know how well it would stand up to the heat. I can't say I've had a failed engine because of it so far.
    I could of sworn my pan didn't have any coating on the inside. If I remember correctly after cleaning it with solvent it started to rust in just a few hours so I sprayed it with WD40. I might have some pics of it.
