One more...If you delete abs, run the cold piping through and can delete some bends.
wow. interesting!
Thats actually pretty clean familyman. Good work .
^thanks
It's pressurized to 20-30 psi. Air fills the whole core no matter which way it's turned. Plus who says air doesn't pass through the whole core? There is nothing prohibiting air from entering the bumper hole (high pressure zone), filling the whole air cavity behind and then going through core.
I see 5-10* IAT increase from the start to end of a 3rd gear pull. Not bad and that is with a $200 CX Racing core.
How tall is your core? 12.5" I assume? I plan to drop my core to the bottom of the front/lower splash guard and making a splitter fit to the top of my ic core dierting air over the core and making the exposed opening to the core smaller increasing the pressure in front of the core while still in theory allowing a good bit of fresh air over top of the core that hopefully the fans can pull air through especially when the a/c is running. Might as well take advantage of the big ol mouth on the bumper...lol
Ill post a pic of what I mean when I get home tonight.
Jason
I see no reason why it wouldn't work. Duct it properly and you should be fine.
I took it that he is saying it would have more effective cooling if inlet is on bottom because the cool ambient air would hit the hot incoming air because that is what is exposed to ambient air. My point is 1) the entire core is filled with hot air, not just the half the inlet is at 2) the whole core should get ambient air passing through if you have proper ducting.
If you are saying he means the piping needs ambient air to pass over it, I guess MAYBE if it was on bottom, exposed to more air, there could be a slight difference in cooling. I have to believe the FMIC, finned core, that is enormously bigger than the small amount of rounded piping exposed to air, will do the vast majority of the cooling.
Here is the core I used. Core dimensions are 24x12x4, plus end tanks...
cxracing.com: Front Mount Intercooler 31"x12"x4", 4" Core: 24"x12"x4", 3" Inlet & Outlet, many applications
i tend to agree. my fmic i'm trying to keep the piping hidden, so those benefits wouldn't matter either.
