Results 1 to 10 of 22
Thread: Fuel Pump Options
    JNS Engineering verified
    San Jose, CA
    Fuel Pump Options
    My stock fuel pump suddenly failed and stranded me 100 miles from home. What are my options for replacement that would be compatible with the stock FPR?
    I see many options on Rock Auto including a couple of Denso and a Beck/Arnley among them. These purport to be stock but no specs are listed.
    A higher flow unit like the Denso 195130-1020 or Kyosan might overrun the FPR right?
    Advice please
    Delaware
    Any pump on stock wiring wont be an issue. I'd probably just put another OEM pump back in. The Wally 255 is a good/cheap option but unknown really how long it would last compared to an OEM pump like the denso/supra or the OEM one.
    Jason
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Ya if you plan to keep it relatively stock I would probably go OEM or Supra.
    Stealth owner since '91
    Sthrn NH/Eastern Ma
    Either the Denso 951-0013 (fuel pump only) or 950-0154 (same pump but with the strainer) will work and are available from most Carquest stores. Not cheap but these are the OEM pumps and are identical to the stock one.
    Here's a link to the Denso catalog http://www.densoaftermarket.com/cata....php?part=fupm
    Avoca, NY
    OEM or any OEM like replacement should be fine but if you ever plan on needing a bit more fuel the Walbro is probably your best bet. I'm actually running a pretty sweet sale on it right now.... Walbro 255lph Fuel Pump with 3S Install Kit - Maximal Performance
    I've got a stock pump with only 40K on it that I've been trying to sell for a while if you're interesting. Give it up cheap.
    San Jose, CA
    Jason
    It looks to me that the 0.73 ohm dropping resistor will drop the voltage pretty low for the Supra pump. Wouldn't I have to bypass the resistor or add one in parallel?
    Quote Originally Posted by Steve '92ES View Post
    Thanks for the link, I think the Supra one is Denso 951-0014. Sound right?
    Quote Originally Posted by Maximal View Post
    Thanks Terry, that does look like a good deal. Just not sure I want to go that route.
    Thanks Greg but I probably will go new or upgrade.
    Someone added another stock one in parallel with great results. Pretty sure the thread on it is on this forum too. Can't for the life of me remember who was the one that did it though...
    I was going to try bypassing the resistor so the pump got 8V (or whatever typical voltage sees in "high mode" without a hotwire) with the relay switched on, and 14V hot wire off the battery with it switched off. One of those projects I never got to... Now that I'm going to be running a Walbro E85, I'm not sure what to expect with the stock resistor in place.
    San Jose, CA
    Thanks for the reminder. This was Larry's work:
    http://www.3sgto.org/f13/erik-gross-...sited-311.html
    He showed that the Supra pump cannot work using a stock dropping resistor as the pump voltage gets too low. The solution (I remembered correctly) was to add a second resistor in parallel to cut the voltage drop in half. Now the supra pump can work with the wiring and the fuel supply is setup to handle 550 cc injectors.
    All that said, I'm going to stick with stock for now. I found a source for about $100 shipped for a new one.
    Greg, can you explain how to set it up this way? I'm sure you are going to use the changover to trigger an external hotwire, but it doesn't come very natural to me to read circuit diagrams. I need real pictures.
  • History
  • Information
  • Groups
  • Events
  • Resources
