Results 1 to 10 of 26
Thread: Questions on Converting DSM SMICs and Radiators
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Hey guys,
    I'll have a break from school coming up and I wanna get a few things sorted out on my car while I'm home.
    1. I want to get a new radiator for my car. What is the best one to get? Koyo seems pretty nice...
    2. When I convert my DSM SMICs, is it worth the hassle of putting bigger diameter pipes on? Some people seem to say the lowered resistance makes a huge difference while other people say the extra welds create more turbulence so it doesn't really make a difference. Is there a consensus here?
    Also, I will be taking the SMICs to someone to get welded since we don't have a TIG. If I use the stock pipes I was just going to cut everything up and mark with a sharpie how the pipes need to line up on the SMICs. Would this work? Is there a better way of doing it?
    Thanks!
    Man vs 3/S verified
    Kingston, WA
    The stock 1st gen radiator is very good IF its not rotted, its worthwhile to keep it if its still in good shape. However, I have a 2" Koyo and like it very much.
    As for the SMIC's there are probably pictures online that could be found detailing what tubes need to be cut where and a before/after pic. Bring your stock intercoolers to the welder and have him match the stock tubings locations to the modified DSM cooler.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    I'd keep an eye out for the 3sx single pass next friday. If they run a good sale on it pick that up.
    ~2006
    I haven't taken out enough stuff to see if the radiator is rotted at the bottom (my old SL was rotted there).. However, just cruising on the highway it will be running around 200*F and after a few autocross runs in the heat it is up to 220*-230*F. I actually like the route you have taken with your car and is what I am after (well rounded, reliable car that you can track without worries). I am also relocating the stock oil cooler to the front hoping that will help with oil temps a little.
    Do you think those temps sound abnormal? I have more water than antifreeze in the coolant (freezing point is around -10*F) and it is fresh. New water pump, as well.
    As far as the SMICs, I was going to mock everything up to make sure it fits and stuff (less room for error for the welder) but that sounds a lot easier if they can handle it.
    Ya, I was going to take a look at the poly mounts (as you recommended) and radiators over the next week hoping they have a good deal. Is the 3SX single pass a drop in/bolt in install? Is it as good as the Koyo? I'm not real up to date on the rads...
    Thanks a lot guys!
    There may also be sales on Mishimoto radiators on Friday
    Thanks a lot guys!
    It is a drop in, you may just have to trim the a/c line studs that stick out of the condensor, but that is a 2 minute job with a dremel.
    I wouldn't say it is as good as a koyo, but it works just fine.
    Corunna, IN
    How good is the dual pass rad? I've always liked it but haven't heard much on it.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
    Dallas TX
    I run the stock rad, never had any problems with it. As far as the DSM's, I run 1.75" piping I believe (been a long time.) They fit inside the stock rubber hoses after dremeling them out a bit. I think stock is 1 and 5/8. I only have like one/two more welds than a stock pipe, so I doubt it hurts at all compared to the increased air flow. At any rate, my IC's stay pretty cool, much cooler than stock.
    ~2006
    Thanks!
    Ya I don't think there is anything inherently wrong with the stock rad, but if mine is starting to go bad I would rather just upgrade it to keep it cool during autocrosses/mountain runs and possible road racing later in life.
    Did you do the conversion yourself? Any tips? Did you pay someone to convert them for you? If so, do you remember approximately how much? I feel like an 1/8" difference wouldn't make a massive difference for what I am using them for (considering it will probably cost substantially more for someone to fab). Good to know you don't think the welds are a big factor, though?
    Thank you
    Dallas TX
    Yes, I was the first one to do the conversion that I know of, so mine aren't as pretty as some other examples done, the welder and I literally used some scrap metal pieces of aluminum he had laying around. Because of that, I've got an extra weld or two that wouldn't have been needed if we had a better supply of tubing available at the time. However, we went back and ground the welds down and polished up the inside of the piping as well with a wire wheel, so they are quite smooth.
    Jeff L used to have pics of my intercoolers on his website, they look just like the last two pics on his "Intercoolers" page (he credits Bob for those pics, but mine look just like them.) One pic of them is on his "front mount oil cooler" page, the last pic shows my DSM's bolted up and using some of the stock tabs from the DSM's, before piping was welded on.
    There might be an old thread of mine on 3SI with more pics, I have no idea at this point.
    I gave the guy $50 I believe, and the intercoolers themselves cost me $50 total. I sold my stock intercoolers for $50, so I remember that my entire upgrade to DSM's only cost me $50. It's actually quite simple to do, if you have any experience welding you could probably tackle this. Aluminum is harder to weld than steel because it cools much quicker though. I would have tried myself but I didn't have a welding machine.
    First thing you do is cut off the stock DSM pipes, which obviously will leave two holes in the end tanks. Then, you need to use a hole saw (1.75" for me) to cut new holes in the end tanks where you will weld the new piping. Take the cutout piece of metal from the hole saw, and weld it where the stock DSM piping used to be, and seal it up. After that, you put the intercoolers on the car because some of the stock DSM mounting tabs will work. Then you can see how the new piping has to go.
    It took us two days, but only three tries to get it right, because my car wasn't at the welder, he'd tack the pipes on, I'd bring it back home, test fit, and mark where adjustments needed to be made. If my car had actually been there, we'd have knocked it out in about an hour or two.
    Using the stock piping would be substantially easier, but then you would ruin your stock intercoolers and couldn't resell them, so... Not that anyone is buying stock intercoolers these days.
  11. The Following User Says Thank You to UTRacerX9 For This Useful Post:
  • History
  • Information
  • Groups
  • Events
  • Resources
