Page 41 of 43 FirstFirst ... 313940414243 LastLast
Results 401 to 410 of 423
Thread: Engine Bay Pics
  1. #401
    Quote Originally Posted by LandmansRT View Post
    Atleast im not the only one to run without tb covers. Great looking bay!
    Don't sweat it man. No timing covers saved my engine. I can't run them because of my adjustable cam gears. I didn't torque my tentioner down after a repair one time. I drove it up the road and started to hear a noise. I pulled over and popped the hood, saw the belt flopping. I shut it off towed it home, only bent one.....that's one valve. not two. one. It would have been much worse if I didn't see the belt loose. The covers are mainly there to keep people from getting injured. I've never seen anyone loose a belt from not running covers. That being said I'd still probably run them if they would fit. I'm not sweating them not being there though.
    1993 rt/tt Not Verified
    wa state
    Yes its almost completely bs-less still has abs(for now), battery in the bay, unnecessary wires, reservoirs and the fusebox needs relocation. But my pulley setup is my favorite no tensioner, idler, or ac compressor, just alt to crank, then crank to ps. Makes it extremely easy to work on. Dont regret it at all.
    great, you just made my winter freshen-up turn into a 6 month adventure
  3. #403
    Padawan garage troll Not Verified
    Newark, DE
    Quote Originally Posted by DuTTch View Post
    looks like a lot going on in this engine. I am following your adventures with billet 19ts
    Sent from garage
  4. #404
    Quote Originally Posted by wingnut View Post
    LOL it will all be worth it in the end when eventually you can jump down in the bay and work on it. PM me if you need the links to how i am doing/have already done all that.
    94 Firestorm Red Stealth R/T
    Performance: Ebay shortram, OBX longtube headers, 3" to Magnaflow muffler dual 2.5" out (no cat, or resonator,*TOO LOUD*), Spec stage 3 clutch, 3SX lightweight crank pulley, Maximal solid mounts, Quaiffe LSD, Short throw shifter, Solid shifter bushings. Cooling: Champion 3 core radiator, hotwired single fan. Brakes: New oem blanks, Ceramic pads. Electrical:Optima redtop, Innovate Motorsports wideband A/F, Glowshift gauges mounted in stock location. Exterior: DDM 8000k 55W HID low, high, and fogs, robomodded, window tint, Lightly* shaded tails, corners, and rear garnish). Weight reduction: full ac, srs, cruise control, charcoal canister, rear wiper, motor, washer fluid bottles, etc... (Future fwd TT)
  5. #405
    Newark, DE
    Quote Originally Posted by Uniuno View Post
    This is shortly after I bought the car. First thing I did to it was the air filter and then painted the valve cover and the intake. (Besides replacing the ol' busted engine)
    And this is how it sits now:
    With the exception of the FPR that I mounted to the firewall, but you wouldn't be able to see that anyway..
    Nice before and after...looks like you did all the vacuum reductions allowed. You have all your injector wires tucked behind the fuel rail? You replace all your brake hard lines (in front of where battery sat on PS wall)? Another easy one for you is to get rid of the cruise control and cables.
  6. #406
    At least my jackstands are reliable Not Verified
    Rochester Hills, Mi
    Thanks!
    The car is a base model so it didn't come with the ABS and lines.. etc.. I use the CC on the highway a lot so I don't think I'll be removing that anytime soon.. I need to get the AC lines back in there though.. you can see the front ones. I was going to relocate the fuse panel too, but I was trying to get the car back together in time for NG so that mod just didn't happen.
    95 Base 3k: 6G74/TT/AWD conversion
  7. #407
    Thanks!
    You remind me of me....too dumb to buy a VR4 lol.
    So when are you starting the AWD conversion?
  8. #408
    Rochester Hills, Mi
    Shoulda. Woulda. Coulda.
    I guess you save money on insurance.. not that it's enough lol
    I've got so many other projects going on right now that I'm gonna hold off on that for a while.. always looking for a good deal on parts in the mean while.
  9. #409
    That's what I did. I got a 6speed with axles, knuckles, trans plate and some other stuff for 600. Then my friend gave me a driveshaft, rear end/subframe. I took the trans apart and welded the trans brace in. Reworked an OBX LCD and installed that while rebuilding the trans.......long story short I had enough of the parts to say WTH, might as well do the AWD conversion.
  10. #410
    Mark had (no surprise) the best engine bay at the TX Gathering... It definitely got my vote.
    Here's my bay: (repost)
