Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: Custom Trunk Sub Enclosure
    94 3500gt vr2? verified
    NC
    Here's what I'm hoping to do. If anyone sells something like this, please send a link, I'll probably just buy it. I'm sure someone has made something at least similar to this. Any help with this project (pictures, dimensions, diagrams) would be greatly appreciated.
    So here's the plan. I want a single 10" non-ported enclosure for my JL Audio 10w3. I want it to fit directly behind the seats (where the floor recesses) going up to the top back edge of the seats, making the most efficient use of that space. I'd like the sub on the driver side and an area for mounting amp, capacitor, etc on the passenger side. Maybe with a plexiglass covering over the amp/capacitor area. Maybe some type of bandpass enclosure for the sub so I don't have to worry about it hitting the seats or getting damaged by anything loose in the trunk. Or maybe something really discreet that will blend in with the trunk interior and be less of a target for theft.
    Let's see some pics of anything like this.
    __________________________________________________
    I'll bet, if you take some measurements of the available space behind the seat, that 2fnloud could plug those into his box-prog and give you some good input.
    Owosso, MI
    <-Works at a 12v shop. I can try and take a few minutes and get some measurements to input into our program.
    NC
    Frontline Fabrication verified
    Morgantown, WV
    I did one a while ago for my JL 15. I did it in 2 parts...the actual box to size and then a cover piece to blend into the interior of the car. I even made a small panel to go down between the box and the rear cover so I wouldn't have things flying up out of the trunk area if there were smaller things back there
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
    NC
    Quote Originally Posted by MeTarzan View Post
    Nice work. Although nothing discreet about that lol. I definitely plan on keeping my rear seats.
    I also hope to mend the original 6x9 enclosures to hold 8's. But that's for another day.
    Morgantown, WV
    Quote Originally Posted by n2nsanity View Post
    Very true...car has tint on it so its hard to see from the outside. When I first put this in my car I had the amp mounted to front so you could see it between the seats and was living in pittsburgh pa at the time and actually they broke in a stole the amp . Now all that is hidden under the cover.
    You will be hard pressed to get an 8 in that 6x9 enclosure, depth will be you limiting factor
    a shallow 8 would work, but why rear? you have the sub. I would try to get a 8 in the door, paired with a proper 2" midrange...add a tweeter in the A-pillar. Make a kick butt front stage.
    Morgantown, WV
    I defiantly wouldn't put an 8 in place of the 6x9s I would replace them with some better comp though
