Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 169
Thread: ItTricky's build thread
    Eagle Lake
    figured since so many people ask about it I would post one up.
    Well I figured its about time i make one of these.
    The ride: 92 Dodge Stealth "ES"
    Pics:
    top two pics are the new ones. with te black rims.
    The Story:
    The car was originally a ES model, FWD Non-Turbo, it has been converted to AWD and TT by wehner. I bought the car July 17th 2007, drove it umtil September of that year and there went the tranny/ clutch. It sat until April of the next year, at that time i trailered it to the cities to a friends and had a guy replace the trans, clutch, flywheel, 2 axles that were bad , some oil lines, an axle mount .... i think thats it haha.
    pics from then:
    old clutch
    Eagle Lake
    new clutch:
    old trans: you can see the plate welded on to the trans, the old mount had sheered off in an accident of the former car.
    So all that was replaced in the cities, took the guy a few weeks mostly waiting for parts. He did a great job on it no complaints. I got a ride up there on the last day of finals for MSU back in what must have been 2008?? i think... haha i took it to UMG a week later and got a nice ticket with it... it drove great, ran strong all until that july..... I was doing a pull against another rt/tt when i shifter i heard a noise and immediately let off ..... I had spun a bearing.... woo hoo! i caught it almost immediately, there wasnt much damage done. I sold the motor to Adam Smith (wipeout) on here. after that i purchased a first gen 2 bolt motor from a friend in wisconsin for $1500, took me what 3 years to do everything with the swap,alot of that was saving up money. It sat for a year before i did anyting to it. I did the motor swap on my own, it was my first.... i should have picked an easier car to do it on lol. It was not fun at all, When we pulled the motor i got rid of my A/c, the vac reduction was already done so i didnt have o worry about that. Got the new motor in, and it wouldnt start, just crank and crank. I had already sent me ECU out to get rebuilt and that was in fine working order.... Turned out it was my fuel pump hotwire relay, it had actually rusted out, went to the store and picked a new one up and holy shit it started..... In the mean time i had bought som new tires ( 245/45/18) Falken Ziex 912, i also had my rims powdercoated by powder werks. They turned out very nice, black looked so much better than the polished aluminum.
    some more pics:
    Most recently I lowered it, installed a newfront motor mount bracket, exhaust, and adjustable rear control arms. Everything looked good, took it for a test drive, everything was ok, figured out then i had an exhaust leak on my rear manifold, pre turbo, whatever i can deal with that for a while, and i needed to get the gaskets in on the downpipe. Well went to head home, got on it and i hear a huge backfire when i shifted. I looked back and all i could see was smoke... I went back up to express care immediately, i noticed coolant in my engine bay, got lucky and it was just the coolant hoses leaking. I basically re clamped every single coolant line minus the upper and lower hoses. Pressure tested it and it held 16 psi no problem. When i had the rear charge pipe off i noticed oil in the rear turbo.... my seals are shot the car smokes like crazy any time i get into boost, otherwise its fine. So next plans are to remove my trbos and send them in to be converted to 19ts, also need some 680cc injectors, and a management system..... i think thats it for now..... i'll add anything if i remember it.
    Eagle Lake
    some new pics from my photoshoot thread:
    nice job!
    Taichung, Taiwan
    Nice build. Looks stock.
    1995 3000GT VR-4 Black
    K&N Air Filter / Topline Engineering Ground Kit / Precat Eliminators / Walbro 255 / DNP Downpipe / 3SX Fuel loop / JDM EVO MR BOV / Hallman Pro RX / 3SX Single Pass Radiator / Tein S-techs / 3SX Rear Control Arms / 3SX Custom Poly Motor Mounts /
    306.5hpawhp 320.5awtq @14psi
    Sold - 1994 Mitsubishi 3000GT Pearl White Base
    oct.2007...
    love fwd tt swaps!!
    nice build.
    Eagle Lake
    ....its AWD......
    oct.2007...
    my bad i jus looked thru the pics didnt really read.
    nice build reguardless!
    Quote Originally Posted by ItTricky View Post
    ....its AWD......
    you should post up more details on it. i don't even know who this guy is that did it.
    Eagle Lake
    Hes a local guy...
