OK. would a 5 spd rear end match the front to rear ratio back up?
no.
Jason
damn you can not win, there is no cheap way to solve this.
Ehhmm, ok Shep is telling me (via email) that there is no way to complete a testing phase due to the cost of it, so I'm now asking for an explanation as to how/why this new material will be stronger.
1996 GTO, Owner since 2003.
MR2, can you invite him here to represent himself, to keep the facts, straight and not blown out of proportion.
Invite Sent.
I know a guy that has I could ask him. He measured the deflection of the stock 6-speed endcase, transfercase cover, and then billet 7075 aluminum. His fix was brazing some aluminum blocks/stock/whatever onto the endcase, transfercase cover, and he also did something for the mid case. It increased the flex 6 times over stock and he's guaranteeing his bell housing, endcase, and transfercase won't come apart. We'll see. He only had DR-500 turbos, went through two RPS C-C clutches, 3 6-speed trannies, and a few stripped gears/broken 6-speed cases because he drives his car ridiculously hard as in high rpm clutch dumps not because he's stupid but because he wants to build it to handle the power. He's a veteran machinist and knows what he's doing with a huge 85,000 sq ft shop at his disposal off hours.
He's planning on selling some endcases, transfercases, degreed stock cam gears, a custom intake manifold, and a few other parts he comes up with.
My Last few emails from Shep
Hello,
No I do not have any threads or data that is publicly released as we are still in the testing phase with our latest gears.
The dsm has a weak output shaft so in the past the fix was to machine the existing output gear and electron beam weld a larger output shaft. This was very expensive and in the end we would still strip gears from time to time.
JohnI totally understand where you are coming from but it is not possible to make one for testing as it would not be feasible to set up and just run one set.
To be clear I was approached about making sets, this is not a market I plan to get into. If it were then yes I would be the one testing them and assume liability.
JohnBeing that these are two totally different gearsets any testing done with the dsm may not reflect or help with the 3si gears. The material is set in place and there is only so much that can be don’t with the tooth count and tooth profile being that we must stay with the oem transfer ratio.
The dsm set has already been run and in my hands, I have attached a picture.These parts are made from certified high grade EN36 steel, quality heat treat, special tooth profile resulting in smooth radius in root of teeth, shot peening. The oem gears are 8620 at best,
It would take destructive testing to give you an actual percentage because it is impossible to know the exact heat treat and quality of metal used in the oem set.
