Page 7 of 25 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 243
Thread: Billet gears for 6spd T-case
  1. #61
    You 6 speed guys really need to get on this list if you are going to drive your car hard. What is the point of upgraded diffs if you can't keep a transfer
    case in the car?
    Fixed
  2. #62
    Delaware
    You 6 speed guys really need to get on this list if you are going to race your car. What is the point of upgraded diffs if you can't keep a transfer case in the car?
    Only issue i see is when making the amount of power you break the 6spd gears...the 5 speed is a better trans :/
    Im 50/50 on putting my name on the list at the moment.
    Jason
  3. #63
    do it
    do it
    do it
    aint peer pressure great!!
  4. #64
    my way of looking at it, we won't be actually throwing money ANYWHERE until it's tested and proven to actually be stronger, so your money is safe, and at only $2.5 that's looking very cheap compared to replacing ANOTHER TC and repairing whatever damage your GB takes when the TC shears off.
    if your running say 600hp+ with a hard clutch and like to beat on your car your name should be on this list (assuming your not selling your car in the next year) do it for the rest of us
    1996 GTO, Owner since 2003.
  5. #65
    Delaware
    Well, unless steve can get us a price on a single unit, i dont think anything will be proven since i dont think we'll get 15 buyers for an unproven part that costs this much cash.
    Jason
  6. #66
    Jason
    Absolutely, before I hand over my Cash I want a Guarantee that one will be sent out to our glorious breaker of all things metal (Andre) and he will get the bash it for atleast 3 drag meets, then take it apart and check for wear/damage etc.
    my name is on that list only if the above happens, we have had too many products that ended up worse than stock.
  7. #67
    Delaware
    Quote Originally Posted by MeTarzan View Post
    I wasnt aware the ones he made were for jsut the 5spd. And the last pricing I saw was $800 for the main and $1400 with the mid housing but I could be wrong....We havent gotten a set price yet but the will probably be close to $600.
    Weeee bit off on your pricing, 950 from Pampena and i think 850 is the current GB price through Pampena.
    Jason
  8. #68
    OG Member verified
    Sep 2011
    Elkhart, TX
    I have a feeling these gears will do nothing in a stock housing. Has anyone measured deflection of the aluminum on the 6 speed housing?
    In the 5 speeds the weak link was two bolt hole passages in one of the corners that were very close together, 99% of the cracks/broken housings started there. I wonder if there is enough flex in the 6 speed housing to allow flex, and then the gears unalign...BOOM, especially with the narrower surface contact area of the 6spd vs. 5spd.
  9. #69
    Delaware
    Are you thinking the mid housing is flexing? I doubt the smaller gear set in the considerably bigger/heavier/strong iron housing is flexing much if at all.
    Jason
  10. #70
    OG Member verified
    Sep 2011
    Elkhart, TX
    Jason
    Maybe the mid, but I would wager that the breaking of the gears is from temporary misalignment versus raw power, but I could be wrong.
