Page 327 of 892 FirstFirst ... 227277317325326327328329337377427827 ... LastLast
Results 3,261 to 3,270 of 8916
  1. #3261
    One fix at a time verified
    Kansas
    Rod hitting oil pan equals frustration.
  2. #3262
    Hitting as need to make adjustments to the oil pan or hitting as in damn my engine is a redneck yard ornament?
    Never mind, I read your other...glad to see it was not the latter of the two
  3. #3263
    Kansas
    Yeah me too. IPS sent me a 2-bolt racing oil pan not a 4-bolt I had requested in the group buy. I ended up switching pans instead of putting my old one back on because a spare I had was quicker to clean up. It must have had a small enough dent on the flywheel side I couldn't see because it's a real faint noise hitting the oil pan. It may be the counterweight too. I'm anxious to see how these turbos and upgraded wastegates work out.
  4. #3264
    Sep 2011
    Missouri/ north Dakota
    Installed my trailer hitch I made on the 3000.
  5. #3265
    May 2012
    Houston, TX
    - Diagnosed clutch issue (dead slave cylinder - "oh, you leakin' boo")
    - installed brass underhood shift cable bushings (one of those "next time I have the MAS/IC pipe out of the way" things)
    - replaced IAC
    - picked up a replacement slave cyl at O'Reilly... installed/filled/bled with fine-quality ATE Super Blue.
    Going to solder in the pigtail for my EVO MAF and swap that in before putting the MAS/IC pipe back together... and I'm debating picking up some intake runners to get rid of the stock accordion tubes with all those vent ports I don't use anymore.
    '91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
    '03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
  6. #3266
    Installed these and upgraded my BSLCD controller.
    Does Hans have them in stock now?
  8. #3268
    Hey!
    Mine are supposed to be in da mail.
  9. #3269
    Finished to 60k after finally having enough spare time to get back into the garage. Drove it around a bit and enjoyed not worrying about the loose timing belt.
  10. #3270
    Jan 2011
    az
    Quote Originally Posted by Beef6 View Post
    Glad you caught that early. Otherwise you would be like me right now.
