Cant wait to hear how you do at the track!! Good work Chris.
Yeah, my stock heads and cams comments all the time are kinda misleading, or should I say, wrong. I do have hi pressure springs cause at one point I tested a few different cam setups before I settled back with stock cams. And I never went thru the trouble to remove the springs for stockers.
-Chris
HAHA... Don't beat yourself up about it. Have you ever experienced the stock valves/springs floating? The general rule of thumb has always been ~8000 rpm's. Have you ever exceeded that on stock stuff? Obviously you took your aftermarket springs to 8500 rpm's this last track visit. You were using the stock tensioner set-up for that, right?
Thought this video was pretty awesome:
Technically, I'm not sure if that's "float" ... Looks like a lot of the people in the comments on these videos are convinced this is just valve "bounce". Either way, the solution is probably stiffer springs.
This was yesterday:
All ready to hit the streets and break the engine in. As usual I will be breaking it in with furious vengeance. Too dark now, and too tired. Time for a shower and snack and tv.
So I will be breaking her in today! Giggidy Giggidy
-Chris
Looks great,
E100 I assume?
E95M5
95% Ethanol
5% Methanol
-Chris
That's nuts how fast you work!! Let's see some street pulls!! I beg of u haha.
Engine break in 50% completed yesterday. Will finish her up today
-Chris
