Originally Posted by
ibsorgn
OKay, I'll start from your first question, no yellow to pin#1
Best I could tell was Pin#1 pink, #2 open, #3 blue, #4 black, #5 black, #6 open #7 yellow, #8 yellow w/red stripe
Pin#9 open, #10 black maybe brown, #11 open, #12 yellow w/dark(maybe brown/black) stripe, #13 yellow w/dark (maybe brown/blue) stripe, #14 white w/red stripe, #15 open, #16 red
Colors to ECU - I don't know
ECU >>>. Not having any problems with it nor have I had any problems so I would guess the ECU is okay.
Multi meter, I have had it for a long time. Used it often. Put my entire race car and the 3000GT together with it, plus diagnosed many items with no apparent problems. I think it's okay.
Check codes with it? Narrow band O2, voltages and continuity on many things. Don't quite understand that question. (Voltage pulses - yes if that is what you mean)
No access to 1st gen vehicles, maybe the only one around that has one.
No, WHY - your response to I question as to whether you were a TT conversation person.
I want to know whether you are responding theoretically or through practical experience? I mean no disrespect as I appreciate your inputs.
