Can any of you rocket scientists tell me how to pull engine codes from a 2gen 3000GT (OBD1 Hybrid) running a 1st gen ECU. For second Gens the procedure is to short out pin#1 and turn on the ignition and read the flashing codes from the engine check light. 1st Gens you jump pins #10 and #12 and read the voltage deflections from pin #1.
My only concern is don't like the idea of shorting out #1 on the OBD hybrid as it may cause a problem using this mixted configuration.
Appreciate any replys especially from you TT conversion folks.
