View Poll Results: What's your view
Voters
66. You may not vote on this poll
  • That's just nuts!
    33 50.00%
  • Like it!
    35 53.03%
  • It's never going to work
    6 9.09%
Multiple Choice Poll.
Page 23 of 47 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 461
Thread: My DR1400 project started today
  1. #221
    Love this thread
    simply awesome
  3. #223
    Wait, do I spy 1G brakes?!?
    You're going to change those, right?
    I am running a BBK GB right now, in case your interested............
  4. #224
    Basingstoke UK
    No, they are 2G brakes. DBA4000 rotors with Yellow Stuff Pads. That combination works really well. Also using braided lines and DOT5.1 fluid, changed regularly. The reason I didn't go BBK (until I find I need to) is to keep rotational mass and unsprung weight to a minimum. I have read that rotational mass is reduction is equivalent to somewhere between 6-15 times physical mass reduction.
    André
  5. #225
    i like it. well...everything except for the hood, i think.
  6. #226
    Basingstoke UK
    The hood is getting changed.....or modified!
    André
  7. #227
    West MI
    Rotational mass makes a much bigger difference if it's on the end of the rotation.. The rotors being pretty centered in the rotation won't make anywhere near 6-15 times difference.. It will probably act more like 1.5 lbs for every lb or so.
  8. #228
    Basingstoke UK
    That makes sense. How does the weight of a bbk compare to stock-ish set ups? That would also be relevant to unsprung mass.
    André
  9. #229
    Most BBK kits are lighter than stock by like 4 lbs a corner....I'd at least get SCE 2-piece rotors, which alone are 3.5 lbs lighter a piece. Or if it's a drag only car, there are even lighter drag racing brakes, I think it was STM that put a kit together.
  10. #230
    Basingstoke UK
    This is a street DD that will also drag. Interesting about the weight thing though. Maybe I'll look a bit closer. I was almost tempted by some Tarox 10 pot 2 piece rotor brakes a while back, in anodized blue. I have to go careful on the size as my track wheels are 17x9's
    André
