Results 11 to 20 of 22
Thread: Weighed my car today...
    I removed the washer tank up front, as well as the wiper and tank from the rear. Also, the power antenna. My next plans were abs and aws. The seats were a huge difference, as well as the suspension. How about emissions stuff under the hood? Theres a lot of junk under there.
    maybe swap the mirrors with less fancy ones...(no fold in, no heated) suspension is a big one...I have no idea what the stock stuff weighs but I know my Tein is far less...only thing is stock suspension has a fantastic ride for cruising.
    a smaller battery is another good one, I am running from a 6.5kg battery
    on my car the rear seat belt retractors weigh heaps!
    lightweight steering wheel?
    1996 GTO, Owner since 2003.
    stow
    aj my son mike vr4 with the same parts you have is 3580 empty, since then we have removed the complete ac. if i remember it is 42 lbs
    stow
    when back over to 3si , only to try and find my post on what the ac weighed. could not find it. forgive me stealthee
    Quote Originally Posted by SilverJester View Post
    Yeah I wanna keep ac and cruise control. I'm not really sure how much weight is left (at least that I'm willing to loose), the only plans I have right now are the seats and AWS delete.
    About another 1000 pounds It depends on how much time you want to put into it. It theres a day when you can remove the entire interior, there is all sorts of brackets, plates, extra bolts, and other crap in there that can be removed, and you'll never know with the interior back in. Airbags save a decent amount if you want to get rid of them.
    Front and rear crash bars are a lot of weight in these cars.
    My car weighs 2760lbs with almost a half tank of gas. I have gone through and removed just about everything possible. I had removed a couple hundred pounds at one point while still reataining a "full interior".
    All it takes is a little time.
    -Austin@STM
    And the list goes on...
    Already have a lightweight battery. How much do the rear seat belts weigh (w/ all the associated brackets/hardware)? I don't want to remove the seats because then it starts to look gutted...but no one ever sits back there so the belts can go.
  7. #17
    Quote Originally Posted by Austin@STM View Post
    -Austin@STM
    Yeah your car is impressive to say the least
  8. #18
    seat belts do weigh a few pounds, also the trunk liner and plastics behind the seat drop a few pounds.
  9. #19
    Most of the stuff you actually see in the interior is the light stuff, its whats behind them.
  10. #20
    as previously said...mine was 3550
    removed rear bumper, interior from front seats back (still had sides/plastics) gutted sound deadener, stillen dp, stock wheels, stock catback, optima yellow top, removed battery tray/washer bottle.
    otherwise car was all stock sheetmetal/glass.
    my stealth is completely gutted, no catback, all steel/glass, stock DS, td05 18Gs, no bumpers, stripped wire harness to bare minimum. weighs in at 2800.
    steve
    97 VR4 12.41 on stock turbos
    91 MR2 13.80 at stock boost
    91 stealth TT with a couple bolt ons
    and a laundry list of others....
