Originally Posted by
Ray Pampena
im sure its FINE. if it runs fine and has no smoke its probably ok. it will push the stick out because there is not enough room for the crankcase to breath out of that one hose you have. if you get any knock at all, it will push the stick.
the swoosh you hear when you pull the stick of from crankcase vacuum NOT positive pressure. the crankvents make a vacuum when the car is not in boost.
make sure your getting no spark knock and make the stick fit the tube tighter
