So... I started making my wide-body, finally. Four inches on either side for a total of eight all around
So far its just a rough lumpy mass stuck to the car, but time will smooth it out. Here's what I have to share for now, anyway.
I followed your custom front bumper thread, that being said I can't wait to see how this turns out because I'm sure it's going to be awesome! Subscribed!
92' Stealth R/T TT-DR-650s, Greddy FMIC, MAFT, SAFC2, Greddy profec B spec 2, HKS turbo timer, Dejon pre-turbo intake pipes, PST aluminum driveshaft, Maximal Tcase bracket, 25 spline trans, Fidanza Flywheel, Spec stg 3 clutch, 3sx underdrive pulley, Solid motor mounts, 550cc injectors, Walbro 255, Fuel lab FPR, Fuel rail loop, braided fuel lines, plenum spacer, Borla catback, Megan DP (giggidy ), gutted precats, 19" SSR D5Rs, Drilled/slotted rotors, Tein S Techs, Aluminum STEALTH door sills and spark plug cover, Dual ARM-1's, Autometer gauges, Front mount oil cooler, 3sx dual pass radiator w/ flexlite fans, RFL BOV.
so...are you going to get tired and sell it in 6 months?
No, I doubt I'll ever get rid of this car, I'll never see my money again if I do.
take lots of pics.
I shall, I want to keep good documentation of this. Every step of the way I'm going to try to take some pictures.
Here's some more progress, I started doing some of the rough shaping so I could have an idea of what I'm going for. There's still some spots where the foam didn't take and will need to be re-filled. I may just use some of the blue board insulation and cut some thin strips to run along all the edges which should make it easier to get the desired lip on them.
P.S.
This brings the car to just under 7' wide
You are going to need to do some door work too or its going to look silly I believe.
not a fan as of now, but i still have faith at the moment
