Just spray it liberally on the output shaft (wipe up the excess) and spray some down onto the spool. Any extra will get squeezed out. Ideally, you're supposed to apply chain lube/wax to a hot chain. So you might want to drive around the block or something with the downpipe disconnected, then come back and remove the TC to spray the stuff. I've never gone to that length though. I forget the exact name of the stuff I use, I switched to Chain Wax for my motorcycle as it's a lot cleaner, I think I used to use PJ1.
