Results 1 to 10 of 11
Thread: awd wheel bearing
    Mar 2011
    oh five
    stop asking, texas IS a shiny penny.
    awd wheel bearing
    i'm trying to replace my front wheel bearing. i've heard that i needed the whoe hub, and that's what i was supposed to get. i didn't. all i got was the wheel bearing itself i believe.
    pretty much what is Pictured here:
    Wheel Hub & Bearing Parts - 3000GT / Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    do i need to remove the hub or something and take both pieces to a shop and have the new bearing pressed in or something? i'm trying to get this shit done before the national gathering, and i'm starting to push my luck.
    what i think should be working doesn't seem to be working.
    _isiah
    awhh, you did it!//oheay fuck you
    _isiah
    The pic you linked is an AWD hub assembly.
    If all you got was a bearing and no hub then you got a FWD bearing. It wont work.
    this. fwd bearings are the opposite of awd bearings.
    fwd = component fronts, assembly rears
    awd = assembly front, component rears
    installing a new awd front is a bolt-on procedure. it's cake.
    Mar 2011
    oh five
    so, i'm hearing that they don't even sale awd wheel bearings away from the hub? wonderful.
    _isiah
    you do realize that at ~$100, the wheel bearing assembly for the AWD front is dirt cheap, right?
    Quote Originally Posted by shmoo View Post
    _isiah
    It's a bolt in wheel hub. Trust me, you would much rather spend $30 more on an awd front hub than to have to do a front wheel bearing on a non turbo.
    Let me know if you need one. I could bring one to the NG.
    This. I absolutely DESPISE doing the FWD front wheel bearings. I do all my own work, except front wheel bearings anymore. We were just talking about bearings in the chatbox last night. I took the steering knuckles off last time and had a machine shop press them out and the new ones in. They quoted me $20 when I called. When I went to pick them up they said they had to charge more because those were the most pain in the ass bearings they had ever did.
    Never finishes any verified
    Wake Forest, NC
    Yes the Front wheel bearing suck on an N/A. Pressing the old out is no problem, it getting the new one in that is a total nightmare. Due to the shape of the knuckle it is very hard to get it positioned flat to press the bearing in correctly without damaging the bearing. We had to build a damn jig and bolt the hub to it to get it level to press the new one in. Thankfully I have a TT now so I don't have to deal with that shit ever again!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    I just use a hammer
    3sx had the cheapest I could find at the time I had to buy some.
