Changes:
(1) Serial expansion board fully integrated.
(2) Reflashing is made easier because null-modem cable is no longer needed. Default flashing serial port changed to the datalogging serial port (female connector).
(3) New PTC resettable fuse.
(4) Supporting hacks are now easier to solder in (ie. External sensor 1, 2, Alchy PWM).
(5) No bulky connectors at the back of the LCDBC box, to make installation easier for steering wheel column mount.
(6) The black sheathing is about 3mm thick, flat (not round), for easier installation, and more pleasing to the eye.
(7) OBD2/MUT circuit uses a chip instead of transistors/resistors circuit. This allowed me to shrink circuit board. This also means jumpers had to be introduced to select OBD1 or OBD2/MUT circuit.
(8) Parts are mounted on both sides of the board, and some surface mount parts to shrink the overall size.
Uses same software as version 2 hardware, essentially this is still the same as the last version, but in a box format.
I this is mounted on top of the steering column, what does it block from your view?
Looks good
Do want. Let me know when you release the new version officially and I will see what I can do about getting one from you.
1995 Dodge Stealth R/T Turbo
Make me some interior pieces Weevil style haha
Anyone that wants one, send me a private message. Only 10 available.
And yes the plastic case was done on the 3D printer.
What does it block if mounted on the steering column? High beam indicator. I don't recall what the other ones beside it are.
Wish I had cash for this and a GM 3port solenoid or a Mac solenoidm
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
1991 Dodge Stealth ES - Sold
Sold.
