Results 1 to 10 of 21
Thread: Idle issue IAC steps
    Never finishes any verified
    Wake Forest, NC
    Angry Idle issue IAC steps
    When I drive the car around and let off the gas the rpm's stay at about 2500-3000 rpm's for almost 25 seconds and then the idle drops down to normal.
    I thought it may have been from a vacuum leak but the pressure test came back with no leaks at all. The just installed a rebuilt TT throttle body with all new seals and adjusted to spec. IAC and TPS all tested fine.
    So I looked at my log files and noticed after I let off the throttle the IAC steps stay between 85-89 then they suddenly drop after 20 seconds.
    Anyone have any ideas what would cause this type of behavior? it is really annoying as when ever I stop at a light or stop sign the car sits there at almost 3000rpms and finally drops back to idle.
    here is the log file and I have the occurance highlighted in red:
    http://3s.gonzoinc.com/albums/userpi...3_16_45_31.xls
    I can't seem to figure this one out!!!!!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Canaan NH
    Is the TPS set so the idle switch is being triggered ?
    Wake Forest, NC
    TPS was adjusted just like is states in the manual.
    0.65 Feeler gauge was inserted between SAS screw and throttle lever, TPS was turned until continuity was lost between terminals 3-4.
    Canaan NH
    Ok, was just the first thought I had. Its a long shot but could your blow off valve be sticking open for a little while ?
    Wake Forest, NC
    It's is not the BOV. If you take a look at the log I attached you will see that the IAC is still sitting at 89 counts even when I let off the throttle. Something "ECU/Electrical" is causing the IAC to stay open when it shouldn't be.
    CT
    Things that effect ISC speed (usually switches or sensors)
    power steering
    air conditioner
    altitude
    talons had some sort of training function that changes values over time, we might have this as well
    deceleration from cruise or racing speed so that air is not cut off to quickly
    coolant temperature
    loggers should be able to check that stuff as well. what kind of speed are you at while letting off the throttle? im also not sure what this training function is but an ECU reset might fix it.
    I wouldn't take this as anything other than stuff no one has mentioned yet. We know for sure the ECU is keeping that step high, and its got to be for a reason. Because it drops down after a short while im really wondering what it could be.
    Wake Forest, NC
    So after some advise from one of the guys on the other site I found out what the FLG0 - FLG2 means on the logger. They are flags for certain switches being on/off. FLG0 has an entry for Idle switch "I".
    So I checked the logger with the car in just the on position and nothing. I tried moving the TPS around some and still nothing. Can't export the log as it keeps crashing MMCD Tools doing the export.
    I would get random T-AN-- when I would move the TPS around which doesn't make any sense to me! TDC is the only one of those sensors even close to the vicinity of the TPS sensor. The AC was not even turned on.
    T-Top Dead Center
    A-AC load Switch
    N-Neutral
    I took the TPS off and tested it with a multimeter and I am getting continuity through pins 3-4 but I have to run the inside plate a little. When I installed the TPS I adjusted it so that when the throttle plate was closed I had continuity! WTF???
    I have a couple TPS sensors I am going to swap in tomorrow and see what I get then.
    Newark, DE
    Sounds like u r following service manual Fuel section. There is a pretty good trouble shooting section there imho, which I suggest u check out and follow. Tps is basically a potentiometer, and sends this signal to ecu as throttle depressed.
    Sent from my Eris using Tapatalk
    91 AWD TT
    Wake Forest, NC
    Followed the manly and double checked everything multiple times. Te idle switch is working and the ECU is seeing it but it refuses to drop the IAC steps back down. Something else is telling it to stay higher and I can't seem to track it down. ECS and ABS have been disabled/deleted so I don't know what else could cause the ECU to see that it needs more airflow.
    Canaan NH
    Power steering switch ?
