Results 1 to 3 of 3
Thread: Fuel Pump
    Fuel Pump
    Looking for suggestions for 1992 Stealth RT/TT with 440 injectors and 500 Turbos fuel pump. Thanks for any help.
    Cheapest is a walbro 255lph. Needs a bit of fiddling to fit, all the shops carry kits. Downsides is install and noise it makes, which is why it's known as the whinebro. The denso pump known as the "Supra" pump because it was oem in the 4th gen supras is quiet and bolts right in. Downsides is it costs a bit more and can require fuel pump resistor delete mod, or if you're crafty 2 factory resistors in parallel. Resistor bypassed mod can potentially create another issue of factory fpr overrun which makes your idle fuel pressure increase which richens your idle. Choose your poison.
    I am looking at a Walbro for $120.47 which comes with a filter and a 255LPH for $108.99 which supports up to 500 HP which mine is. Both are guaranteed to fit.
