Results 1 to 2 of 2
Thread: Gas Pump Credit Card Skimmers...
    I'm Marcus
    '98
    Denver Colorado
    Cross posting & spreading the knowledge:
    A local tech company that I've done alot of business with out of Boulder, CO called Sparkfun worked with law enforcement to help them reverse engineer the technology that some thieves are using at the gas pumps to steal your credit cards. The tech is not all the same, but a common technique according from sparkfun is to embed a unit in the gas pump that stores your captured credit card information in solid state memory and then uses Bluetooth to transmit the information to the thieves when they visit the pump to pick up your info.
    Sparkfun built a "scanner" app for an android phone that you can use when your at the gas pump and if "sees" the common blue tooth signature that some of these skimmers use - it warns you.
    For information on the app see this Sparkfun blog post:
    https://www.sparkfun.com/news/2487
    If your into the tech side of it see this deeper article that talks about the work sparkfun did:
    https://makezine.com/2017/09/21/unde...card-skimmers/
    and
    https://learn.sparkfun.com/tutorials/gas-pump-skimmers
    cheers,
    duke3k
    Favorite Car - A 1998 RED VR4 , pretty much stock except: Suspension: '94 ECS Struts Retrofit w/ Tein H-Techs controlled by TechWorks ECS Suspension Controller
    www.renegadetechworks.com Open Source 3000gt ECS Retrofit & Replacement Controllers
  2. The Following User Says Thank You to duke3k For This Useful Post:
  3. #2
    Nice, what would be nicer if they put in the code in their app to send the "delete stored card info" command........that way we could go around and just broadcast the delete code at every gas station we visit. Or send the "E" disable command, that would be better.
  4. The Following User Says Thank You to anyonebutme For This Useful Post:
