BAH! More issues. More updates.
I've spared you all my frustrations with my alignment issues, but yesterday I went back to the shop and had them re-do my alignment. Still only 90% happy, but I digress...
Some history and what happened: The car has been progressively getting leaner at idle. Especially when it warms up, which is counter intuitive due to air being warmer when entering and thus not as dense. Even in the stock ROM, fuel is added on cold start and taken away as engine temp increases. When I did my first pull in it, it felt slow. Really slow. Log did not have a steady AFR but recorded rich (low 11's). Just acting odd.
I drive it yesterday to the alignment shop and it's running pretty lean. Fuel isn't coming in like it usually does when pressure builds (I wasn't flooring it or anything, just building some positive pressure). I get to the shop, the car doesn't want to idle when it's started up /embarrassing.
After alignment, I drive car around a bit (a few miles) just to see what it feels like. Gets worse. I flash 2 more times, adding fuel at idle each time. No change. By this time I'm concerned and head home (I was about a mile away). Car is extremely lean when cruising home. Like 18:1 lean. Barely wants to idle. Really being a butthole.
So my assessment is a fuel issue. It's suspicious that all of this started when I put the DLI on, but I don't think that's my issue. I mean, it could be I suppose... but due to it getting progressively worse every time I've started the car, and then working its way to undriveable... the DLI wouldn't get worse. It might be bad but it would be consistently bad. I'm somewhat confident in my fuel concerns.
Attack strategy:
- My fuel filter is a Russell with a 10 micron filter. Supposedly ok for E85 (I was told when purchased)... I never changed it from my previous (gasoline) setup to now. Maybe shame on me? IDK. Everything I read says don't use paper filters with E85, and I took it out last night and sure enough it's paper. I just called Russell and the guy says they aren't compatible with E85... Gonna get a Fuelab E85 Filter. The 828 series is the plan.
*aside* why the hell don't you say that the filter isn't compatible on the website then, dumbass Edlebrock!!*
- My fuel lines are lined with who knows what. I bought them from a performance shop YEARSSSS ago... I can't remember. I *thought* they were PTFE but I'm questioning everything now. Le sigh. I have teflon fuel line in my garage already so I'll make some new lines this weekend.
- Since I'm doubting everything now, I'm also going to get my injectors cleaned. I'm concerned time-wise with this part. I also don't know if there's anywhere local for this. I'm gonna make some calls today.
While I've got it all torn apart, I'm going to change plugs too, so I can try and make sure I'm starting from square one. Then there will be no more variables to go wrong left. What a pain in the dick. I really hope with all of this, the next time I put my foot down, the car does the boot scootin boogey cause I'm getting disheartened.
