Results 1 to 10 of 12
Thread: stock FPR
    the BOSS of jellow supporter
    May 2005
    Dairyland
    stock FPR
    does it need to know the intake manifold pressure? should I leave the vac hose connected? top part of my firewall is pretty clean now...
    Those, who stand for nothing, will fall for anything.
    On the Internet you can be anything you want. It's strange that so many people choose to be stupid.
    Cazenovia, NY
    Yes, but you don't need the crap solenoid it routes to. That's only used for hot starts. Send the line straight to the font plenum port by the throttle body.
    xtreame360 - could you elaborate on any more info you know on this? why does the TT need a solenoid for hot starts but the NA's dont? very strange.
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by a2j View Post
    Yes, the FPR is a 1:1 rise FPR. For every 1psi manifold pressure the FPR rises 1psi. Without a vac/boost reference your fuel pressure will not rise and you will not have the fuel you need.
    -Chris
    Cazenovia, NY
    Quote Originally Posted by TUFFTR View Post
    The solenoid is supposed to dump fuel or lean it out (can't remember which one) for hot starts. You don't need it though.
    May 2005
    Dairyland
    Quote Originally Posted by Ninja Performance View Post
    -Chris
    yes, this sounds familiar, that is why I was asking. does this apply also for the aftermarket AFPR?
    I AM IMPORT POWER
    Driving Vicki Crazy
    It is actually for warm starts not hot. And you can remove it. I have never seen a negative effect from removing it.
    -Chris
    I AM IMPORT POWER
    Driving Vicki Crazy
    Yes, and for the same reason.
    -Chris
    May 2005
    Dairyland
    -Chris
    so, without it, I should not have problem staring in cold/hot with e85?
    I AM IMPORT POWER
    Driving Vicki Crazy
    Not in warm, hot weather. However Ethanol does not vaporize down in cold temps like gasoline so it will be harder to start in cold temps. That has nothing to do with the FPR solenoid.
    -Chris
