Results 1 to 8 of 8
Thread: E85 questions
    E85 questions
    So my car is basically stock other than an EBC, aftermarket DP and gutted cats. Could I just run 450cc injectors, supra fuel pump, new filter and just jack up the fuel pressure with an aftermarket fuel regulator? The computer would think I'm still running the 360's so I wouldn't need to change the fuel maps? It would be rich as Swiss chocolate on 93 octane but E85 I should be good right?
    Frontline Fabrication verified
    Morgantown, WV
    its roughly 30% more e85 over 93oct so the 450s might be just undersized...The supra pump isn't compatible with Ethanol & I wouldn't try to do something with fuel without some kind of fine tuning like an AFC and a wideband O2
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
  3. The Following User Says Thank You to MeTarzan For This Useful Post:
  4. #3
    That's what I was afraid of. I was under the impression that all modern FI systems were made to tolerate ethanol?
  5. #4
    Most of the fuel systems prior to early 2000ish can only tolerate about 10% ethanol, which is how much most pump fuels contain.
    iowa
    Ray is running a stock filter , with those basic goals.in mind.just get a safc or maft get a walbro made for the e85 if i could get e85 in town every car I could do would be e85 . Such a pain to get it for the talon
    Sent from my HTC Hero S using Tapatalk 2
    Feb 2011
    Scottsbluff, NE
    Get 450s, a wideband, SAFC, Walbro for E85, and you should be good to go. Make sure you change the fuel filter often or get one with a stainless steel filter element.
    1995 Dodge Stealth R/T Turbo
  8. #7
    I AM IMPORT POWER
    Driving Vicki Crazy
    Agreed with E85 Walbro ad SS fuel filter.
    -Chris
  9. #8
    Delaware
    Here is a paper filter from a Camaro after 4 years of continuous use:
    Jason
