1993 $ 8500
Pictures by bnbovey - Photobucket
That URL will take you right to my photbucket album to see pictures of the car
I'm restarting this thread to see what interest i can get
I am selling my 1993 Dodge Stealth RT/TT it has 107,xxx miles on the body but has a JDM motor with approx 45000 miles on it, it has a lot of mods I will list off I had it retuned and redynoed about 4 months ago, it put down 513 AWHP/ 489 Ft/lbs at 22lbs This car runs great and pulls hard the motor is fresh i just dropped it in it came out of a completly stock car so it has never been pushed and i have not pushed it at all so far i will save that for the new owner, this car is a lot of fun i don't want to sell but i need to at this time.
Starting price i am going to ask is 8500
List of everything done to it
4 bolt block JDM drop in with Aprox 45,000 miles on it
Transmission was rebuilt 10,000 miles ago
New transfer case 5,000 miles ago
Fidanza aluminum flywheel
3SX dual spec stage 4+ unsprung clutch
Aluminum one piece driveshaft
3SX TD05 Turbo kit with non MHI 16gs with Turbosmart 38mm external wastegates, I have an extra rear manifold I will send with it
Front and rear pre cat eliminators
3SX downpipe
Cat replaced with test pipe
3 inch Borla exhaust
AEM EMS tuned for water/meth at 18lbs and 22lbs
AEM water/meth kit 1 gallon with inline filter and new nozzle
AEM water/meth failsafe device
AEM Tru boost controller
AEM A/F ratio gauge with O2 6 in 1
HKS turbo timer not hooked up but has harness
3SX dual pump/ dual feed fuel system with dual walboros and 3SX fuel rails
RC 750CC injectors
Dejon pre turbo blow thru red intake pipes with K&N filters
Dejon Front mount intercooler with red pipes
Turbosmart dual port BOV
Accel 8mm spark plug wires
NGK coppers
3SX ball bearing short throw shifter
Battery relocated to trunk
Optima red top battery
3SX solid motor mounts
Megan racing coilovers
AWS delete,
Adjustable rear camber arms
Powerslot slotted rotors
Stoptech street performance brake pads
Steel Braided Brake lines
18x9 saleen replicas with brand new Kumho ecstas 255/40/18
New paint job summer 2011
OEM wing replaced with 1998 3000GT wing
Interior is in good shape it is red and black
Bose double din in dash dvd player
1200 watt mono amp with a single 10 kicker/L7
Aftermarket Steering wheel
Spare set of OEM wheels with tires on them
K&N Oil Filter with Rotella 15W40
Vaccum Reduction Kit
That's what I can think of right now off the top of my head the car is clean it doesn't have any rust on it at all
