Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Can I remove this
    Can I remove this
    My 6-speed trans is leaky from both of these bolts, my question is are they just bolts or do they play a certain role in the trans. Also can I remove them and use some thread sealent to make sure they dont leak?
    Madison Heights, Mi
    My bet is that you need to pull the trans and reseal the case.
  3. The Following User Says Thank You to Alan92RTTT For This Useful Post:
  4. #3
    It doesnt seem to be leaking from the housings. I traced the leak and it comes from these big bolts.
  5. #4
    Anyone? It leaks from that big bolt that looks like a handle! Can that be removed?
  6. #5
    They have a purpose, the long one is the reverse detent and the other is the shift detent. You can remove them (might want to have it in neutral). DO NOT take a pipe wrench or something like that to the tall one. You will damage it. You must use a wrench on the base of it. I think I had to grind down a wrench to get it in there. Pick up some good sealant to use%
    Awesome thanks, im planning to remove them and use sealant, you wouldnt happen to know the torque specs for them?
  8. #7
    They use aluminum crush washers.... sealant won't do much.
  9. #8
    Quote Originally Posted by Z16A View Post
    20-26lbs
    I can get the exact torque when I get home but I know it's about 24.
  10. #9
    The drain/fill plug is 22ft-lbs so I was gonna tighten them to that.
  11. #10
    the top one is 24ft.lbs (long one) and the bottom one says 15ft.lbs.
