View Poll Results: Which engine
Voters
31. You may not vote on this poll
  • Built 72 with DR heads
    14 45.16%
  • Strokaaaah but with stock heads
    17 54.84%
Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 89
Thread: Engine Dilema...
  1. #51
    I don't bite
    Southern IN
    Sounds like you won't change your mind but why spend all the money on a build like this and not have your cam timing perfect? Granted I had DR cams but the difference between just installing with the normal settings and actually degreeing are literally night and day. Spool is almost 500 rpms better and tq is holding better to redline.
  2. #52
    Delaware
    Because 1/4 of a tooth doesn't concern me enough if the heads even get decked. Todds neither time from pampena have had the timing off at all after being checked/cleaned/pinned.
    Jason
  3. #53
    If I get rays 3.5 I'm not concerned about random failure.
    Exactly
  4. #54
    Jason
    One of Eric's front cams was off 9*. That makes a real difference. The only way to tell for sure is a dial indicator, piston stop, and degree wheel.
  5. #55
    I don't bite
    Southern IN
    "Only" 8* off, so no problem Others were 1-5 off.
    BTW one tooth is 7-8* so a 1/4 tooth is 2* and it should be a concern since +1/-3 makes a difference on stock cams so 1-2* that could end up in the wrong direction would as well.
    From personal experience, I don't feel it's splitting hairs. Do what you want of course and if your heads are never touched, you'll be fine but just wanted to make sure the significant difference it can make is expressed.
  6. #56
    Well I'm convinced.
  7. #57
    Delaware
    Im going to be running STOCK cams, stock cams always degree correctly installed straight up. The regrinds are almost always off, some so far off they cant even be degreed correctly *cough* BC. Though oohnoo's DR streets were all within 1* of being correct. The inconsistency is annoying along with the lack of quality cam gears.
    Jason
  8. #58
    When you change the distance between the crank, and cams, you change the timing, regardless of the cams/gears. The front head sees 3x as much change as the rear, because the belt is routed back to the block before driving the front head gears.
    A stroker with stock cams is just crying power left on the table anyway. Going from 3.0 to a stroker would require at least 264 cams to keep the stock 3.0 power band on the larger engine.
    On a turbo car, the most important parts to make power are the turbo, cams, and intake mani, everything else being the same.
  9. #59
    Delaware
    Blehhh....you're right. I'll see if i can afford it.
    4800 bucks for heads/cams/UR gears/ported lower intake manifold.
    I love being poor.
    Jason
  10. #60
    I lack color... verified
    Aug 1998
    Yes but you have to build the car according to how you can afford it.
    Cams are an easy swap later on when you can afford them.
