Results 1 to 10 of 16
Thread: Valves
    Jan 2011
    az
    Valves
    I know this might sound stupid but would it be efficient to mix valves like different brands? Not like mixing them on the same side, but say I buy a set of crower intakes and a different set for the exhaust side? The whole intake side would be the same valves and the exhaust will be a different brand? I haven't done this yet. Just wanna see what most would say but I think I already have an idea. Lol
    Medford OR
    I would not matter in the least.... The only thing that would matter, is if whatever you used was of sufficient quality to reliably perform the task required.
    Jan 2011
    az
    But as long as the 12 intake are the same and the 12 exhaust are the same ? Then I should be ok .
    Frontline Fabrication verified
    Morgantown, WV
    Yep ^^^^^^
    They have no bearing on each other
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
    Oct 2010
    Chicago-South burbs
    OK, I have a question for ya guys. A member on here had his heads worked on recently. He has +2mm on the exhaust and +1 on the intake. I tried to advise him to keep them both the same size, however the PC mechanics must have convinced him otherwise. I have searched quite a bit and have not seen any mixed combo like this. I am NOT saying it won't work, it's just not the "norm" I guess. Thoughts?
    -Dan
    Quote Originally Posted by DanEboy5 View Post
    -Dan
    ^^^^^ He's talking about me lol.
    Jan 2011
    az
    I've heard of some heads that are setup similar. But I think the do 2mm over on the intake instead of the exhaust . I think the ips race heads are setup that way .
    VR-3747 :D Not Verified
    Dayton Ohio
    a lot of race heads have different size intake/exhaust valves. i want to say even DR stage 3 heads have different size valves, but i looked on their website and it doesnt say specifically
    Jan 2011
    az
    If I can remember I think the heads that were on matts race car were only 1mm over on the intake and the exhaust side was stock.
    Oct 2010
    Chicago-South burbs
    Quote Originally Posted by jspecmike View Post
    I wasn't trying to call you out on it...lol but you did! Did you find any research on this like we talked about? I didn't find anything.
