Page 23 of 59 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 590
Thread: My 1992 GTI
  1. #221
    I'd much rather torque to spec than just crank the hell out of it. Removing it should be possible with a pipe wrench, but it has threadlocker, so maybe not very easily.
    Tie rod was cake, and so was the axle. It took me longer to install the new tie rod boot than to swap the tie rod.
    Some jerk wrote on my dirty old wheels, haha:
    So I replaced them:
    Old wheel/tire weight:
    New wheel/tire weight:
    I've got the alignment at 1/32" toe out, about -1.5* camber in the front, and the rear at 0.8* of camber. Feels superb, and rolls really nicely now.
  3. #223
    Canaan NH
    Looking good.
  4. #224
    Transmission is stuck in 3rd gear. Hurray. Trying to pick up a replacement on Sunday ~3 hours each way...
    Pulled the trans last night:
    The clutch thankfully appears to be as new as the PO says it is:
    VW in its natural habitat:
    Drained the trans and pulled the diff kit tonight. The fluid is tasty...
  5. #225
    Transmission is in My self-adjusting clutch cable broke, so we tried to swap in a manual adjust cable and ran into silly issues and I was tired so I went to bed lol. My brother finished swapping my clutch cable for me today. Just drove to class, new (used) trans + delrin shifter bushings = tranny sex... wait, what? seriously though, it feels great. The manual adjust cable feels like poo, but I'll deal with it for now. New self-adjusting cables are expensive and likely to break, plus they can make the clutch not fully engage.
  6. #226
    Drink it!
  7. #227
    No thanks, haha
  8. #228
    On the 3SPA cruise last weekend my clutch bolts backed out and the pressure plate fused to the crank and then fell off and damaged the end of the crank. I fixed that, but the damage done to the thrust washers by me forcing the clutch pedal down ruined the bearings and they ate the crank. So...
    New crank is pulled from the short block my brother picked up yesterday. Forged cranks ftw.
    I'm thinking I can install it and then bolt the trans up and do the timing belt to get that stuff out of the way. Swapping bearings is relatively easy with that stuff done.
  9. #229
    1993 rt/tt Not Verified
    wa state
    Backed out?
  10. #230
    Yep, moron PO reused stretch bolts that bolt the pressure plate to the crankshaft.
