Results 1 to 6 of 6
Thread: GI: Rebuilt 5-speed 25-spline transmission with Quadco XR OS
    One fix at a time verified
    Kansas
    I need to liquidate a few items and eventually I need to cut down on how many transmissions I have. I'm gauging interest on this transmission only because I don't really want to get rid of it but I need to sell something so it's whatever goes first.
    This 25-spline transmission was completely rebuilt by Auto Velocity back in '09 when I purchased a 93 VR-4. It has less than 300 miles on it because I had the car shipped, did a complete rebuild/upgrade path for huge power, and ultimately lost interest in the build. I had planned on using this for 800+AWHP with the rest of the drivetrain supporting mods so I installed a new Quadco XR output shaft in it. I also have a SS assembled transfercase that can go along with it for extra.
    One of the ears on the bell housing needs welded back on. Either the transfercase didn't go on right or it got bolted up wrong and snapped. I'm not sure what the cause was but it needs to be fixed.
    Due to the condition and mods I would like to get $1500 plus shipping for it. I can work with someone on shipping the item. I expect freight to be $300 or less.
    I decided I'm going to keep it for now.
    Kansas
    August 2003
    Uniontown
    Where are you located? This transmission has miles from after the rebuild? No leaks? How much extra for the xfer case to come with it? And how many miles on the xfer case?
    Kansas
    I bought a 93 VR-4 in '09 with a bad rear turbo. The engine ended up having a spun bearing without the previous owner disclosing it. I only drove the car about 20 feet before it sat where I worked on it for 2 years doing too complicated of a build and then lost interest. The car has issues on the dyno and was driven ~300 miles home by the previous owner. I could dig up the receipts for the transmission work. I meant to keep the transmission so I bought a Quadco XR OS for it, installed it, put it back in the car, but ended up taking it out when I parted the car.
    The SS transfercase came from a different car and has ~15k miles on it. I have the 3SX receipts for it also. It had a new SCE input spool installed at the time too. I have a new 0 mile SS transfercase already I bought in '10 or else I'd be keeping the other one. I'm asking $1500 for the transfercase since the front and mid housing plus the new spool cost that much alone. I'll take offers though.
    I'm buying a SCE center diff which uses its own special length 300M OS which means I can't use the Quadco. My zip is 66610 in Topeka. If you can't come pick it up and live in Uniontown, KS I can put you in touch with Elyria_boy here on the forums. He's out of McPherson and could deliver it for you since he travels all over the tri/quad state area delivering parts for tractor companies and would work out a deal.
    August 2003
    Uniontown
    Shit. I used to live at Ft Riley. Im in uniontown, pa.
    Kansas
    Damn. I was hoping you were still in Kansas. I have a guy interested in this transmission and a shortblock so I'll be looking into shipping.
