Results 11 to 20 of 36
Thread: Records... 1/4 mile times, whp?
    See sig for details on 9b's. We ran 11.97 last year almost full weight, 93 octane, crappy FMIC, and street tires, which was enough for the previous record.
    This year was E-85, 2800lbs ( now its down to about 2740, and will be 26xx next time at the track). Gonna try for the all out td04 record with the 9b's
    -Austin@STM
    And the list goes on...
    Pass Me Another Hooker
    Toledo,Ohio
    Added. T0d5, dr. Lines.
    Keep the times and other things to to add. I will mock them in until I get to my laptop.
    Tried to change the title to. The records books, but it wouuldnt let me
    Also both setups for me are Stock block/heads/cams/manifolds, all never been ported/removed.
    Billings, MT
    Quote Originally Posted by 93SlugTT View Post
    I don't know if I would add the TD05 lineup as they are not a direct bolt-on upgrade and require the use of an aftermarket headers kit. I figured you were looking for JUST bolt-on kits. Or are you compiling a list of ALL 1/4 mile records for each turbo setup?
    And 11.97 almost full weight?! Damn Austin, that's badass! Keep up the good work! I still say you should stick with the TD04s (DR-750s) and see how far you can push that envelope.
    1997 Mitsubishi 3000GT VR-4 - Currently being torn down to rebuild...
    1998 Mitsubishi Eclipse GSX - 14B Turbo, BSEK
    Toledo,Ohio
    Austin, will add in a couple minutes. Thank you. For the help.
    Toledo,Ohio
    Quote Originally Posted by Apache View Post
    at first it was to be bolt-on, then i started going with it,
    whatever the people want, is what i will make it
    If you are looking for hp records as well, as far as i can tell i have the HP/TQ record for stock turbos and it was done on a low reading mustang dyno to.
    Like i said before if i get a deal on some td04's or someone wants to let me borrow a set i would do it, otherwise its not worth the money to upgrade twice.
  8. #18
    Billings, MT
    I believe you're also the only person insane enough to put that much money into pushing the stock turbos. And on E85 no less.
    And 93SlugTT, I'm afraid that if you try to get numbers for EVERY turbo setup out there that it'll be VERY difficult to do as there are a LOT of options out there nowadays. I think sticking with just bolt-ons and getting that list finished would probably be a good place to start first. But it's your thread, and I'll help in any way I can.
    P.S. Austin I have a set of low mile DR-500s that are just collecting dust right now. Was planning on using them to replace my stock ones, but I've since re-evaluated what I want out of the car. Not sure if they would be much of an upgrade though. Let me know what you think.
  9. #19
    Toledo,Ohio
    Bolt on. Turbos it is
  10. #20
    San Francisco
    Check out 3squicklist.com for more
