Ok, so I've done the vacuum reduction, and I have the FPR and bov on the rear and front throttle body stems, respectively. I just got Blackstealth's LCD gauge setup, and the control unit needs another vacuum source. The install guide says to "T" it off of the BOV or some such. I'd rather have each of the lines (other than the waste gates from the solenoid) to be dedicated lines. I was curious if one of the stems on top of the throttle body could be used? Did a search on both sites, no one actually had an answer to this. Thanks!
