Results 1 to 8 of 8
Thread: Boost Issue
    Jul 2012
    Pennsylvania
    Boost Issue
    when i hit my factory peek boost level the car makes a high pitch sqeel and or beeping sound almost its hard to exsplain.
    I think its boost loss but from were is the issue im having any suggestions would be nice i dont know were to start looking?
    because the car runs fine otherwise mind you 130,000miles 1991 bone stock
    Probably the stock BOV.
    Could also be a bad check valve on the clutch booster or the brake booster. Need more info on where the noise is coming from like Stealthee said.
    Jul 2012
    Pennsylvania
    The OEM BOV is what i was thinking to but it only does it at the peak of boost clime does the oem bov have intermitent issues like that
    It sounds like its comming from the drivers side thats why thought it was weird
    STL, MO
    Best way to tell if it's a boost leak is to pressure test the system. That will tell you if your bov is f'd or if you have any other leaks. The clutch booster/brake booster is also another good possibility Like Doc said. But test the system and see what you get. Also videos always help.
    1991 Stealth RT/TT
    Jul 2012
    Pennsylvania
    can you recomend a tool to pressure test the system or a how to online
    anything will help hanks
    STL, MO
    You can buy a pressure tester for 3sx. It goes in the intake bubble it's self. Pretty easy process. There should be something on stealth316.com
    Jul 2012
    Pennsylvania
    ok thanks
