We found ourselves trying to source good used ones so often (Due to the factory units completely rusting away) we figured it was time we just made a replacement The hat is 100% Stainless-steel and TIG-welded right here at IPS.
NOTE: The hats come “bare” with no electrical connector, fuel pump or fuel level sensor
- Hardware and instructions are included with the kit
- Comes with new gasket
- -6AN return fitting comes with the cap (for those using their stock fuel system and not needing the optional return)
- Comes with -6AN to fuel line adapter to re-use the stock fuel line (basically a replacement for the rubber hose going from the factory hat to the factory fuel feed line)
$250 + shipping
