Where is the OEM oil pressure supposed to be on the gauge when at full operating temp and at idle on the oem gauge and how do i correct for low oil pressure
The stock gauge is junk, but it is usually at the second tick from the bottom. You could use a heavier oil to bump up pressure, but if it really is low your best bet is new bearings and a pump.
Thanks lol whats the point of the guage lol
is there any kits or mods for upping the oil press a little
Yea, a healthy engine :P
Unfortunately there are no easy ways to bump oil pressure. The factory gauge is just not trust worthy, for one it doesnt even tell you pressure, just has marks. First step is to install a decent gauge. If the pressure really is low it means the bearings are worn, if you ignore them you WILL spin a bearing and be left with a junk engine.
well easy or not I'm not worried I'm not an armature when it comes to this stuff but i know from experience a lack of lubrication is not good on internals and i was wondering if any one has tried the old dirt track washer trick by putting washers between the pressure relief valve spring on the oil pump
what is the oil press is supposed to test out at max and min
12-20 psi at idle, 80+ psi at 4k rpm and above.
the relief shimming is possible for us, but will only raise the peak oil pressure. At idle the pump is not outputting enough pressure to open the stock bypass as it is.
Like others I have found 2-3 ticks from the bottom at idle to be typical on the stock gauge. At cruising it should be at or above the first big mark.
Now, on fresh bearings and oil pump my last engine idled above the first big mark and was 1-2 ticks below the 2nd big mark at cruising (about 2500 RPM)
A real oil pressure gauge is a good investment. IIRC 2 ticks from the bottom was about 15 PSI on my last car, but it has been years and years since I had the stock gauge and aftermarket at the same time.
You can cheat a little and bump up the idle speed by opening the biss screw a bit, but your idle won't be as consistent. The oil pressure will be higher though.
