Results 1 to 3 of 3
Thread: Fixing the tick w/out $$$?
    Owosso, MI
    I've had very minor lifter tick for about a year now. Recently it's gotten worse and I want to remedy i, however, I just dumped $400 into a new clutch/plate/bearing. I am more than willing to do the work but just can't afford a new set of lifters right now.
    There are so many different opinions on what causes it and I want to know - is there a way to get rid of it outside of replacing them. Can I simply clean them individually? Is it possible to drill the hole into the chamber a little biggerto keep them from going dry?
    I'm just brainstorming here because I'm broke. If I had the cash (along with the wife's go ahead lol) I would just buy new ones.
    Any ideas?
    Member
    Chilliwack BC
    Your problem may not be that the lifters are gummed up, here's a copy of what the FSM suggests-
    LASH ADJUSTER CHECK
    NOTE
    If the clanging noise due to the lash adjuster produced immediately
    after the engine has started or during operation persists,
    perform the following checks.
    (1) Check the engine oil, and add or replace if necessary.
    NOTE
    (1) If the engine oil level is low, the air drawn in from
    the oil strainer will be trapped in the oil passage.
    (2) If the engine oil level is higher than the specified
    level, agitation of the oil by the crankshaft could cause
    a large amount of air to enter the oil.
    (3) A deteriorated oil contains a large amount of air, because
    the air, once trapped, is not readily separated
    from the oil.
    If the air trapped due to these causes enters the high
    pressure chamber in the lash adjuster, the air in the high
    pressure chamber will be compressed while the valve
    is in the opened position. The lash adjuster will be drawn
    too far in, and will produce noise when the valve closes.
    This is the same phenomenon that occurs when the valve
    clearance is adjusted to an excessive dimension.
    In this case, the normal condition will be, restored if the
    air escapes from the lash adjuster.
    (2) Start the engine and slowly race* it several times (less
    than 10 times).
    If racing the engine causes the noise to die away, it means
    that the air has escaped from the high pressure chamber
    of the lash adjuster and that the lash adjuster has regained
    its normal functions.
    * Accelerate the engine from the idling speed to 3,000
    rpm slowly (in 30 seconds) and then decelerate it
    to the idling speed slowly (in 30 seconds).
    NOTE
    (1) When the vehicle is parked on a slope for a long
    period, the oil in the lash adjuster will decrease. When
    the engine is started, the air might enter the high
    pressure chamber.
    (2) After a long period of parking during which the oil
    in the oil passage goes away, it will take some time
    before the oil is re-supplied to the lash adjuster. Therefore,
    the air could enter the high pressure chamber.
    Key Largo, FL
    I don't know if you have a turbo car or not, but for the NA's, you can use motor flush before changing your oil. It usually cures my lifter tick until the oil starts to go bad. Can't do it with a turbo car though.
    2013 NG: 1st place, FWD Drags
