1995 3000GT VR4 - pearl yellow 1 of 42 - race car!1992 Stealth ES - saved from the junkyard - community loaner car1996 3000GT base - purchased 2006 - WRECKED/PARTED1991 3000GT VR4 - rusty POS Edition - SOLD
If you plan to spend that much money on an ATX, why not convert to an MTX instead? Its already known that an SOHC MTX is compariable to a DOHC ATX.
I am also modding my SOHC ATX and one of my future plans was to convert to an MTX. My ATX isn't in the best conditions and cost wise I think its cheaper to swap than to rebuild/upgrade the trans.
No weight reduction will be done to mine, except maybe an aftermarket hood and rims. Anything else is pointless on a SOHC. Just remember this rule, "For every 100 pounds removed, you save a 1/10 of a second on the track." You would have to shed 1000 pounds in order to drop 1 second.
Rims alone will net a good weight lost. Here's another rule for you "Rims weigh 4 times there weight when spinning." Drop lets say 10 pounds per rim, and you have 40 pounds less standing. Those 40 pounds become 160 pounds less than stock when spinning.
Now knowing this, think of what a washer bottle will reduce. Doesn't make much sense to remove it now does it?
Besides your list, I will have everything except the 10:1 pistons. I like the fact that my SOHC is non-interference.
The only reason I will be doing upgrades is because I had a rebuild of the engine planned since I am over 200k miles on it. Might as well upgrade as I replace. I personally just want my SOHC to be a little faster. Plus I already blew some of my money buying some parts, might as well install them now. After this The rest of my funds will be saved for a VR4.
My car never broke a damn thing when it was stock and I beat the ever living shit out it as a dumbass 22 year old. Since its been modded, even the minor way it is now, it takes little to get shit to break.
Going "track only" in a NA SOHC would be a bit of an embarassment. Its flat out not a good candidate for that. If you want real power, but don't want to sell the car, go through with a DOHC TT swap. You will spend a shitton less money and be worlds faster. Then you might actually have an excuse to make it track only with having the ability to run 12's on stock boost as long as you get traction.
The thing here is this; the mods you have listed in your first post don't amount to anything unfortunately. Our cars are pretty open from the factory as it is. Injen intakes are quite possibly the highest priced pieces of tubing I have ever seen in my life and I don't understand why they are still in business. The plenum spacer = nothing. Crank pulley, ground wires, and MSD plug wires offer negligible gains, if any, as well.
The mods you plan to buy are just a waste. You add all the mods you have put and plan to put in this car and you could have yourself a reliable, unbroken VR4. Stock they run 13's and for less than $3k you're in the 11's easily.
The auto SOHC is the bastard child of the 3000GT platform... it's not flaming. It's simply the truth. Why they decided to include such a motor in the same platform as the TT and VR4 just baffles me.
The platform was based on the VR4 and the TT as the top dog.
Dodge used the SOHC exclusively until Mitsubishi, for some reason, decided to take the reigns after the Stealth ceased production.
Not saying the SOHC doesn't have it's perks... it's nearly indestructible! It's not for modding. Why? Because the VR4 exists.
No, you misunderstood. The 3.0 SOHC was around since 87. The DOHC didn't start being made until the 3000GT. The SOHC is the birth engine to the 3s.
