You guys don't notice a front mount when u see one do you? Its an awd tt converted car
It is admittedly pretty hard to see in your sig. I'd hope that since you mentioned the turbo it would be fairly obvious it has turbos though
I've had the rear manifold partially off while the engine was in the car. It's definitely removable.
Well its currently the least of my worries, Monday I lowered it, installed exhaust, adjustable rear control arms, and my front motor mount bracket. Everything went ok, took it for a test drive, that's when I found ou the mani was leaking as was my dp... forgot to buy gaskets (have them now, just not in) so I go to head home from my buddies shop get on the highway and give it some gas, shift 2nd to 3rd.... big backfire right as I look in my mirror all I see is smoke..... I literaly stopped traffic it was so bad. Fml at this point, I limp it back to the shop coolant in the engine bay.... too late to look at it. Next day I decide to take a look at, my oil leak.... Oil cooler has been deleted, 2 plugs to block off the lines both leak slightly, I pull them out, Teflon tape them and go to put them back in.....and strip one out, after am hour at least we get it re tapped and pluggedno leak.... Time to go home at this point. Next day (today) get there after work, and tear out intercooler piping to find out I have oil in my rear turbo.... So yeah sounds like forced upgrades.... Did get the coolant figured out all my small coolant houses decided to loosen up at the same time... But yeah time for bed....put in 36 his in 3 days working on cars ha.
